Anyone with Carbon Fiber Fender Vents?
slowride
Midwest
2018 PMM Type-R
I've got a couple of terriers also, thought they looked similar
Honda Civic 10th gen Anyone with Carbon Fiber Fender Vents? q6aiiVy
davemarco
How much of a PITA was this? I'd like to make these my first mod, but not really feeling having to remove my entire fender liner and brush glue primer on the back of my new carbon side vents.
JayDiem
Tyler
Colorado
2018 FK8, 2007 Ram 1500, 2000 CRV
It's not that bad. You don't have to remove the entire wheel well covering, just the first 3 screws and a few clips and pull it back and tighten one Phillips head screw. The other clip is reached thru the hood opening.
Honda Civic 10th gen Anyone with Carbon Fiber Fender Vents? 20190312_175932
Honda Civic 10th gen Anyone with Carbon Fiber Fender Vents? 20190312_175950
davemarco
Thanks. Do you also have to apply adhesive like the previously posted instructions suggest, or is it a screw in piece?
JayDiem
Tyler
Colorado
I didn't use any tape, just screwed it into place with the lower screw and top bolt. If someone were really a perfectionist double sided tape might help everything stay a little bit tighter towards the bottom, but I am not concerned with it right now.
Mick the Quick
Mick the Quick
Mick
Southeast MA
2018 PMM Civic Type R (R-08508)
Looks great - is that the one from Seibon?
Unyot
Unyot
Merced
RSX-S aspec/CTR
How’s the fitment and build quality of the Seibon fenders?
fatherpain
Tom
Honda Civic 10th gen Anyone with Carbon Fiber Fender Vents? DF06610C-E589-439C-9C20-D38A4186757F
Installed APR CF fender vents. Was a painful experience (literally). Your arms get torn up reaching inside the fender to reinstall the upper plastic push clip.
Beware: The upper hole on each vent needs to be enlarged to 21/64
Honda Civic 10th gen Anyone with Carbon Fiber Fender Vents? 8AAE6209-B524-4525-849F-7855F47B20EA
Fitment is nice however.
davemarco
Thanks. Did you just use a drill bill to widen the hole?
fatherpain
Tom
Hi davemarco,
Yes. Started with a 5/16 then finished with 21/64. Did it very slowly with barely any pressure so it wouldn’t grab hard and snap it. Looking back, could have used some lube for an extra measure of safety.
Full DIY walkthrough posted Here
davemarco
Hi davemarco,
Thanks. From your write up, it sounds like the too-small hole is a known issue with the APR side vents. Would you willing to reach out to them to let them know about the issue? I don't know that I'd feel comfortable drilling carbon fiber, so I might have to wait for a future batch.
