Higgo8
- Steve
- Nov 25, 2016
- 161
- 60
- Stoke-on-Trent
- 2017 FK8 CTR GT
Only 3... that's disappointing!
$800 shippedWhat was the reduced price?
You can bead roll titanium without issues. Not sure why you think you canât?From my knowledge of titanium, you can't roll a bead..... at least as far as I know
Also since this is a inlet and its not under pressure it has no chance of blowing off. Its not like a charge pipe.
Make some custom coolant lines to match and you got me as a buyer. lol
Hey.... what I am curious about is heat. Ive not done much with Titanium except for exhaust so I don't know its characteristics of heat transfer.
I wasn't trying to be a d**k .... as I stated "from my knowledge of titanium"... maybe I should had wrote "limited knowledge"? After doing some research I didn't realize, just like stainless, there are apparently different grades of titanium. And yes certain grades can't be bent or rolled without cracking. This is why you see a million pie cuts in certain bends that could easily be ached with a mandrel bender using stainless.You can bead roll titanium without issues. Not sure why you think you canât?
I donât think you understand why a bead or machined lip is present when using hoses and clamps. Have you ever seen a throttle body, air box, thermostat housing, vacuum line or anything using a hose without one?
Titanium is absolutely awful at conducting heat.
It doesnât heat soak like thicker materials. After a few seconds of fresh air it cools off due to the nature of it. The stock turbo inlet stays cool longer but also stays hot longer due to thickness. You need to take into account more than the fact it gets hot. Truth is everyone should run a turbo blanket like I do if you care about heat and problem solved. The whole bead roll is not needed. Unless youâve got blown motor mounts with your motor flopping around it wonât come off. Even then I doubt it would. I do think the price is high. I also wonder if anyone has adapted prl turbo inlet to another intake style.Pretty much defeats anything âcoolâ from the intake.
I will concede that if it is FULL Titanium, then it would not radiate as much heat as an aluminum. However, the stock inlet pipe isn't radiating inside the intake path either - the thickness of it was designed just for that factor. Outside is hot, but inside is not affected. Contrary to popular belief, vehicle Air Intake designs are the best configuration, as are the DPs and Exhausts (for stock turbos). The Intercoolers are really the only weak link when to vehicle is pushed further (and for longer) than the manufacturer ulimately designed it for; which was "daily driving" with occasional spiritedness.It doesnât heat soak like thicker materials. After a few seconds of fresh air it cools off due to the nature of it. The stock turbo inlet stays cool longer but also stays hot longer due to thickness. You need to take into account more than the fact it gets hot. Truth is everyone should run a turbo blanket like I do if you care about heat and problem solved. The whole bead roll is not needed. Unless youâve got blown motor mounts with your motor flopping around it wonât come off. Even then I doubt it would. I do think the price is high. I also wonder if anyone has adapted prl turbo inlet to another intake style.
Ok can go with that statement cause other than volume the inlet tube doesnât allow enough heat penetration cause the air is not dispersed over a large area like an intercooler. Although after 15 minutes of driving the stock turbo inlet was roasting inside and out. I took it back out cause I thought I might have had a coolant leak. Iâm one of the unfortunate people had stud snap off in the turbo. Thatâs was with heat. Got so pissed off I bought another turbo. How much heat actually transfers is unknown but it dies get hot straight through. Prl pipe is titanium as well but Iâm at odds about buying it cause I have a mishimoto intake and donât know if I can adapt it to it. If I buy both prl intake and inlet Iâm at 900 bucks either way. Has anyone tried that with prl.I will concede that if it is FULL Titanium, then it would not radiate as much heat as an aluminum. However, the stock inlet pipe isn't radiating inside the intake path either - the thickness of it was designed just for that factor. Outside is hot, but inside is not affected. Contrary to popular belief, vehicle Air Intake designs are the best configuration, as are the DPs and Exhausts (for stock turbos). The Intercoolers are really the only weak link when to vehicle is pushed further (and for longer) than the manufacturer ulimately designed it for; which was "daily driving" with occasional spiritedness.
And YES, the price is high, but Titanium costs more to harvest and produce - then, you have profitability.
