Braiton
- SI_GFX
- Jul 14, 2019
- 32
- 247
- 157
- New York
- Honda Civic SI 19'
Hey guys, today I went to install headlights on my civic si. The drivers side worked perfectly. The passenger side’s day time running lights did nothing work.
I tried many different orientations and could not get that daytime running light on during any setting.
After that, I took off the new ones and was just going to throw the stock lights back on while I wait for a new part or something.
I’m deeply confused because when I put my stock halogen light bulbs back on with my LED headlights from
LASFIT, there was an issue.
When I put the stock lights back on, I tested them and both sides weren’t working besides high beams.
And
I tried so many different orientations, plugging things into different sides, different holes, different side of the clip going together.
I had to wrap It up for the night but this is where we left off:
Drivers headlight on:
DRLs work
On low beam setting, just fog light is on, low beam not visible.
on high beam setting, low beams for both sides are on..?
On the passenger side, on the low beam setting, the drl, the low beam, and the fog light is on. Also when you put high beams on, this side also just displays the low beam setting.
so I drove home with the highbeam setting on, which was just my two normal low beam lights.
I don’t understand, what am I doing wrong? Faulty part, but even if that’s the case then why doesn’t my stock lights work.
And
DRLs work
