Xtelotatichl
- Cha
- Jan 1, 2018
- 9
- 304
- 231
- USA
- Civic si
Lol!!Proof reading is a bitch.
Honestly at 8000 miles if your clutch is not holding anymore I would take it to the dealer IF and ONLY IF I knew I didnt abuse the hell out of the car or cause it myself because if they tear it down and find that it was due to my abuse Id be on the hook for them taking it apart and putting it back together.take it an and try to have the clutch replaced under warranty. but the stealership will prob say its a wear item, and not cover it
...but wouldn't there be MORE power at a higher rpm? The horsepower peaks higher, so if you floor it at 2000 rpm's, you would have less power to the clutch, correct???Even if the clutch pedal is out, the clutch still has to hold firm in place to transfer power from the engine to the wheels. Too much power for a particular clutch will cause the frictionable material to slip, even while engaged.
This is what I mean... If you are at a lower rpm, and you step on the gas, there is less power being sent to the drive-train through the clutch.Even if the clutch pedal is out, the clutch still has to hold firm in place to transfer power from the engine to the wheels. Too much power for a particular clutch will cause the frictionable material to slip, even while engaged.
Power is not the problem. Torque is. They are not the same thing.This is what I mean... If you are at a lower rpm, and you step on the gas, there is less power being sent to the drive-train through the clutch.
This. When it comes to transmissions and clutches torque is what you look at (and hp but mostly torque).Power is not the problem. Torque is. They are not the same thing.
Just pony up and buy a clutch, why would you want the dealer to install another stock clutch for you that will take a shit at another 8k miles. (This is assuming they even entertain the idea of replacing your clutch under warranty, spoiler.... they won't 9/10) Also what everyone else said, adjust your driving style, you're better off wringing out every gear to accelerate fast than just matting the pedal to the floor in 3rd or above from 2000rpms.I’m not concerned with not getting it fixed by the dealer I had planned on getting a new clutch. I just thought I’d see if anyone else has had issues I’ve been reading about a bunch of 17’s that have had the same thing around 10k miles. All I did was flash the tune you can’t change anything if I remember correctly with a tune that was locked by someone. Has anyone tried to get a new clutch from a dealer. I know pyro was going to try lol
Exactly what this guy said. Don't bother trying to replace the clutch under warranty. It is a waste of your time and theirs. Just upgrade it and call it a day. You and your car will be thankful.Just pony up and buy a clutch, why would you want the dealer to install another stock clutch for you that will take a shit at another 8k miles. (This is assuming they even entertain the idea of replacing your clutch under warranty, spoiler.... they won't 9/10) Also what everyone else said, adjust your driving style, you're better off wringing out every gear to accelerate fast than just matting the pedal to the floor in 3rd or above from 2000rpms.
