MrWaYne
- Jan 12, 2019
- 10
- 115
- 33
- GER
- Honda Civic X 1.5L CVT Sport Plus
hi there,
iam about to install a subwoofer and i found an amp that can boost bass frequencies in the 30-80hz range.
https://www.esxaudio.de/english/signum-se2000d-amplifier.html
sounds about fine and exactly what we need for our HU? right?
also check the manual, which gives more in-depth explanation:The EXTENDED BASS CONTROL controllers allow a extensive adjustment of the bass frequencies. The SUB BOOST controller defines the bass bosst from 0 to 18dB. With the FREQ RANGE controller you are able to adjust, on which frequency the bass boost (SUB BOOST) is effictive. The range goes from 20 to 80 Hz. With the Q CONTROL controller defines the Q-Factor of the crossover continuously, so that the playback quality of the cut-off frequency can be adjusted. Thereby you are able to adjust perfect transitions between the loudspeakers. • WIDE equates a Q-Factor of Q 0,3 (position very left below) = very wide frequency range. • NARROW equates a Q-Factor of Q 1,0 (position very right below) = very narrow frequency range. • Q 0,5 / LINKWITZ-REILLY is the standard-setting at the center position (12 o’clock position). • Q 0,7 / BUTTERWORTH is located the position right (3 o’clock position)
