BERN_017
- Jason
- Jun 2, 2023
- 7
- 33
- 9
- Houston, TX USA
- 2020 Honda Civic EX Hatchback
- Build Thread
- Link
aFe SCORCHER GT Power Module
***DM me if interested***
Details:
- Dyno-Proven Gains up to +38 HP & +46 Lbs. x Ft. TQ (Tested on a Civic Si)
- Quick and Easy, Plug-and-Play Installation (~30 Mins)
- Increases Turbo Boost to Improve Performance, Efficiency, and Throttle Response
- In-Cabin, On-the-Fly Power Adjustments via LED Light Switch
- Leaves No Trace on ECU (No Footprint)
- High Quality Case and Wiring Harness w/ Factory Style Connectors
- Compatible with Other aFe POWER Products
A simple 30 minute install will give you a huge increase in power. The aFe POWER SCORCHER GT Module includes a high quality case & wire harness with factory style connectors for an easy plug & play installation. A LED light switch provides In-Cabin On-The-Fly power adjustments. The 4-Power settings are adjustable with one button and the LED light represent the settings: Stock (Green), Sport (Yellow), Sport+ (Orange) and Race (Red) . This performance module increase turbo boost. It improves vehicle performance and throttle response. In testing, this module resulted in significant +38 horsepower and up to +46 lbs. x ft. of torque verified by our in house dyno.
Direct Plug & Play Power: This quick and easy plug & play SCORCHER GT module adds significant power by altering pressure sensor signals to increase turbo boost to improve vehicle efficiency, power and throttle response.
In-Cabin On-the-Fly Power Adjustments: SCORCHER GT modules features In-Cabin On-the-Fly power adjustment to accommodate any situation. This adjustment is controlled by via LED light switch with a button that can be easily mounted in any location in the cabin.
High Quality Case & Wire Harness: aFe SCORCHER GT modules uses high quality aluminum extrusion black powder-coated enclosure casing and factory style connectors which requires no modification to your factory harness. These factory style connectors, plugs directly into the stock wiring harness connectors and sensors.
High Precision and Quality: SCORCHER GT modules are 100% tested for proper protection. These modules work amazingly on stock vehicles and are optimized for maximum performance with use of aFe POWER performance products.
aFe POWER does not recommend to use with any other tuners or modules.
This SCORCHER GT is not CARB exempt at this time and is not legal for sale in California or use on vehicles registered with the California Department of Motor Vehicles.
Vehicle Applications
Year | Make | Model | SubModel | Engine | Fuel |
2018-2022 | Honda | Accord | L4 1.5L (t) | Gas | |
2018-2022 | Honda | Accord | L4 2.0L (t) | Gas | |
2016-2023 | Honda | Civic | L4 1.5L (t) | Gas | |
2017-2023 | Honda | Civic Si | L4 1.5L (t) | Gas |
