NickfromSD
- Feb 25, 2016
- 12
- 92
- 28
- San Diego
- 2016 Civic EX 2.0L
- Vehicle Showcase
While i still remember id like to acknowledge an issue that's affecting many 2016 civics, in the hopes that all you new car owners can report it to your dealership and we can get a legit fix from Honda.
When i first bought my car i realized that the A/C has a fluttering noise coming from the driver side center vent. I dropped the car off at my dealer overnight so that they could try and fix the problem. They took apart the bezel to gain access to the vents, in the hopes that they might find a loose piece of tape or Styrofoam that was out of place; however, this wasn't the case. They then replaced the plastic bezel in the hopes that this would make the noise go away, but this also did not work. When i arrived at my dealership to pick up my car, we walked the lot to listen to different '16 Civics to see if this was a common issue, and it turned out about half of the cars on the lot made this same noise. With no more plans of attack, they told me that this is unfixable until Honda gets to the bottom of it, which will only happen if enough people report this as an issue.
People, if you are experiencing this noise, i urge you to tell your dealership so that we can get closer to finding a solution. If you have the patience and time to have them physically service your car, please do it. I'd appreciate you reporting back your results.
Id appreciate if you guys could chime in what model you own and whether or not you are experiencing this problem.
