TxSi
H Badge Faithful
- Apr 24, 2017
- 3
- 87
- 67
- Houston Tx
- 2017 Honda Civic Ex HB FK7
How am i not being clear? I have a 10 gallon tank. Just like you. And every other civic. I left dealer with a full tank of gas and only 22 miles on the odometer. I ran it as empty as i could to see its mpg. I know it can be done with a few gallons. Im not stupid. I wanted to see it based on all 10 gallons. My average mpg meter is even stupider. It says im getting 22.8mpg, wich is less than its getting. However if u guys here go by that maint minder thing then im not surprised at the responses im getting here. Lol i use real world figures and math. Not look at a comp counter that is guessing. If you have a 10 gallon tank and u end at 266 miles, not kmh, thats 26mpg overall. Idk how much clearer you can possibly get? Math does not lie. Lol"Range" is "how far you can go on a tank". "MPG" is about efficiency, which is how many miles you've gone per gallon -- and you don't have to drain a tank to find MPG, you can check it even if you only refill with 3 gallons.
Considering that the difference between 9.5 and 10.5 gallons is around 25-35 miles (ish), which can change your "range" from, say, 250 to 280 miles, you're better off just filling it to the top every time and using the trip odometer's readout to calculate your miles-per-gallon. You could do like we did in the days before trip odometers and keep a log book in the glove compartment, writing down the main odometer reading at every fill-up.
It's hard to say whether you're actually having a problem or not when your data isn't very clear.
FWIW, my gas mileage depends a lot on how I drive the car. In my EP, I used to get as low as 20 mpg, or even lower if it was a race day; but when driving carefully (like with my wife in the car), I got high 20's, and even better than 30 mpg a few times.
Ultimately, though, tracking MPG is best used to watch for trends. A sudden drop in MPG that stays low through a couple tanks (and no change in driving style) could indicate a problem with the engine. Generally, though, you're going to drive and refill no matter what, and fluctuations in gas prices will affect you more directly than how much fuel you're actually burning.
