Forge Recirculating Valve
charleswrivers
Charles
Kingsland, GA
Got a question because don’t know lol!! What his the idle PSI for this cars? -8 , -9?!?
Generally... yes... I see it read down around that. If I remember right, true vacuum is around 30 in/Hg (I've seen them on scales that go as far as 36), and we stay on a psi scale... and -10 psi oughta be around the ~20 in/Hg of vacuum my other turbo cars that have read at that scale have at idle.
Loccust
Iowa
2017 SI Coupe
Forge is a good reliable company. I used to be heavy in to the VW world and their stuff is highly recommended in that group. I have their catch can installed on my SI since I still had it left over from my GTI. It is definitely better than the OEM part for sure.
Nitori
Arizona
2019 Civic Si Sedan, 2016 Toyota Tacoma
Necroing the shit out of this thread... :wave:
My experience with Forge was born from being into the VW scene over a decade ago, and having a Mk4 GTI that ripped its stock DV before the 10,000 mile mark.
However, you might want to look closer at the Forge unit before putting it on your Honda.
Honda Civic 10th gen Forge Recirculating Valve valve picture
Everything seems okay, right?
But wait, look at the crescent shaped port for the outlet/recirc. Note that it's roughly 180 degrees around the center, but there's a bolt hole right in the middle.
Now look at its mating surface on the car:
Honda Civic 10th gen Forge Recirculating Valve turbo inlet pipe screenca
Crescent shaped port around the center, roughly 180 degrees... but not in the same place!:hmm:
No matter how you bolt up the DV, those ports will not match up. I'm thinking that's probably a pretty important detail.
I have an email in to them right now, trying to figure out WTF is going on exactly.
  • Like
Reactions: Myx
LightX
Andrew
2018 Civic Hatchback Sport
Just checked my boomba recirculating valve and compared with the stock. Also the hose with the stock is cheap, started to rip somehow...
Honda Civic 10th gen Forge Recirculating Valve 60426569_334580303872491_3196531342783283200_n
Honda Civic 10th gen Forge Recirculating Valve 60461041_459961421446598_3971648707782246400_n
Honda Civic 10th gen Forge Recirculating Valve 60920004_841215679591033_6727520138322509824_n
Honda Civic 10th gen Forge Recirculating Valve 60957214_360084218196978_7100627181436403712_n
Myx
Delaware
@Nitori This was a pretty good observation. Thanks for posting up the pics and info.
Finallygotasi
Chicago
2017 si
How does this valve working for you? I got a 17 so with a Bov and I cant find a stock one to save my life. So was wondering if you've had any problems with it
LightX
Andrew
Works great, no issues that I've noticed so far over a year.
