It was a joke. Hence the "bias".can anyone take you seriously when you post a videogame video? guess you missed the other video posts - and can't be bothered to find videos that arn't forza or one's that are 100% biased.
please - tell me how a wet track test is at all an objective test? using cellphone timers? really - please try harder next time.
The Type-R is also faster at these tracks:
http://fastestlaps.com/tracks/grand-tour-eboladrome
http://fastestlaps.com/tracks/circuit-de-nevers-magny-cours-gp
Focus RS did it's Nurburgring lap...8:06.
type-R (2016) 7:50
Type-R (2017) 7:45.8 IIRC
not sure what else to say.
I will stand corrected thought - it seems the actual reported failures are within the standard levels for national ford quality. so, in that it's not a BAD car.
well, only partially wrong, but play martyr it fits well.It was a joke. Hence the "bias".
The second video was not.
Well, you have proven me wrong. The Type R is indeed faster than the RS on the track. Honda has the better product, Ford need to go back to the drawing board and not come back out with another RS that has more than just cosmetic mods.
I could go on, but it's all there to read yourself.After some digging through Ford documents, turns out this car doesn't even have a differential unit at all. There are electronically controlled clutches in the center diff as well as one for each rear drive axle. There are a network of computers, hydraulics, and robots controlling torque to each wheel. Lots of fancy doo-dads that are neat on paper, but terrible in practice. Hopefully there are some industrious folks who can crack the code and reprogram this unit to work better for performance driving.
One of the worst features of the rear suspension is this trailing arm torsion blade. This is a 1960s-era design used on the VW bug, where you use a flat spring steel arm that can accommodate the suspension arc by twisting. This arm is needed to locate the suspension fore-aft during travel. Massive rubber bushing up front also allows for all of this twist. That front bushing should get a spherical. You only do this type of rear suspension to save money.
The rest of the rear suspension is heavy, stamped steel bits. Not an ounce of aluminum anywhere back here. This seems to have been done for cost savings. I would expect more from a nearly $38K car, but I guess I'm picky. At least they improved on the janky rear swaybar endlink design used on the Focus ST, but that is about it.
This Focus is made by the same company that designed and built the S550 Mustang (shown above), which has an independent rear suspension light years ahead of the Focus - and which can take real power to a properly sized rear differential. Aluminum is used on the throughout Mustang's rear suspension to save weight. And while some of the GT350 Mustangs (non-track pack cars) are seeing differential overtemp issues on track, it seems to be a programming glitch. This only affect the small portion of these Mustangs that even have a temp sensor in the rear differential housing. We've seen S550 Mustangs being abused on track for years with no long term negative effects.
It does, doesn't it?well, only partially wrong, but play martyr it fits well.
I was wrong with the quality of the car - it's rated higher than base civic from Edmunds/J.D. Power (could that be the civic I looked at was base and the RS is premium? not sure that point matters) , and even though I can't find any crash data i'd assume it did well.
the new 2018 limited edition DOES have a LSD in the front; which will help it ALOT...
It's so obviously clear that the Focus RS is just a high powered street car, where-as the Type-R was a purpose built performance/track car
All this bickering back and forth with nothing but opinionated editorial youtube reviews/comparisons and lap times are just laughable and a pretty damn good example why car forums are dying
That's not even the point...and nobody was arguing that they aren't built off econoboxes...I mean I prefer the Honda due to the less complexity however you are kind of delusional if Honda also isn't just a bit tarted up street car. Every manufacturer uses those techniques to cut costs, I've worked on Hondas since the late 90's, Hondas are not immune from cost cutting. Both cars are econoboxes first. Advantage Honda has is that the new Type R is on a brand new platform, while the focus RS is on a chassis introduced in 2004.
Spot on. For a petrolhead like myself in the market for a hot hatch, it's the performance that matters most, specs are secondary. The CTR is built to be fast around a track, period. The FoRS's aim is to have sexy specs that may attract the more mainstream (HP, AWD, "drift mode"... etc).That's not even the point...and nobody was arguing that they aren't built off econoboxes...
The Civic Type R was a purpose built, fastest FWD Civic car out there. The Type R development was done when they reached that goal. It is the fastest CIVIC and the fastest OEM FWD car available.
The Focus RS was built to be an AWD, turbocharged hatchback and nothing else. Boosted engine + AWD system + hatchback -->> great, put it for sale!
That's the difference between the Type R and the Focus RS - the very point of this thread.
"Drift mode"Spot on. For a petrolhead like myself in the market for a hot hatch, it's the performance that matters most, specs are secondary. The CTR is built to be fast around a track, period. The FoRS's aim is to have sexy specs that may attract the more mainstream (HP, AWD, "drift mode"... etc).
I'm too big for the RS sadly.bunch of fanboy remarks from bunch of people that has never sat behind the wheel. Focus RS is a incredible car to drive.
Same. I was at the Montebello Ford the day they got their RS on the lot. Sat in it and immediately could not get comfortable with the positioning of the seat. A shame because I was really looking forward to it and had been following its launch as closely as I've been following the CTR launch.I'm too big for the RS sadly.
