Bluebeejay28
- Benji
- Dec 17, 2021
- 0
- 8
- 1
- Canton
- 2017 Honda Civic Si
Any update ?
Any update ?
Many good observations...This is the difference my "brick for flow" k20c1 made with a simple port job. 50 to 70whp gains plus faster spool everywhere.
Drop in cams for Type Rs have made 40whp+ very easily and on the top end can make an 80 to 100whp difference as rpm climbs past 7300ish where the stock cams fall off a cliff
Waste of money? Lmfao The dynos don't lie
Cams are pretty simple - the stock ECU won't let you overcam the car anyway as it makes tuning a nightmare due to the currently locked VE charts it references for fueling. To run a really race level cam you'll need motec which solves the VE issue immediately. Even on stock ecu tho more duration and lift improves breathing across the board. A little goes a long way so the drop in grinds can make huge gains without much downside.
I would still like to see fuel lobes within 5% of stock so fueling isn't altered too much. Test those against the larger fuel lobe units to see where the chips land. I haven't seen ported L15 results yet or a cammed L15 on a large drop in. Would be interesting to see for sure.
The Si/Accord and the Type R use different ecu and fueling strategies so it's tough to say how much of an impact the VE tables will be on Si vs R.Many good observations...
I unfortunately do not know the limitations of stock ECU tuning. I know there ARE limitations present regarding the locked Volumetric Efficiency (VE) charts when it comes to camshaft upgrades, but I don't know how big of an actual problem it is. Does anyone have an idea on the challenges faced when tuning around this? I am hoping a simple port job, and a drop in cam won't cause much issue.
While also on the point of fuel lobe sizing, Hondata's Fuel system massively increases the fuel lobe lift and duration. I thought the fuel lobe sizing was a non-issue, is that not the case? Does doing everything at the same time (intake, exhaust, & fuel) make tuning too much of a headache?
Aftermarket solutions like Motec offer a way out of the conundrums but I feel like if I have to switch to a standalone ECU then it's no longer a "road car."
The one burning question is can the L15b7 in stock form support raised rpm window. Given the oil pump and rods might become an issue at say 8000rpm....500rpm higher should be ok - folks might find out the hard way once the motor itself CAN flow to 8000 but the bottom end might not stay together making the power and rpm without some help.
Either way the cams will make power to stock rpm but typically cams allow the rpm range to be pushed up but that's IF the engine can stay together up there. For Type R 8200 is about the edge - of hpfp and bottom end - I just don't know if the rpm has been tested on a stock bottom L15b7 - hopefully we see those numbers soon and then anyone who wants to replicate will know where the safe rev range is. Testing - another reason I share my findings, including the setbacks.
It's just wild when people say stuff like ported heads lose power or cams are a waste of money Makes me laugh
Edit 1: I seem to have some made an error regarding "MAP having tested a stock bottom-end upwards of 10k RPM." I believe I was looking at a video where they do not exceed more than 8.5k RPM.
Edit 2: But I found the original video clip and it's here! (What Breaks when Making 500+hp with a 10th Gen Honda Civic Si? - YouTube) It does say 10K!
I believe at the moment they are running the exact same profile as the SI fuel lobe. As far as I know, the fuel lobe is identical for all of their cams.I wonder how the kelford fuel lobe shape compares to the hondata fuel lobe shape. I wonder if all the kelford cams also have the same fuel lobe shape also.
