Featured Why doesn’t the Civic Type R have torque steer? (Engineering Explained)
  1. 360glitch
    360glitch Moderator
    3,458
    3,334
    2017 Civic Si Sedan
    A great video from my favorite YouTube series:
  2. Vortexhunter
    Vortexhunter Senior Member
    Sep 17, 2017
    204
    187
    Occupation:
    Electronics Engineer
    Herts, UK
    PMM Civic Type R GT #10432
    I've asked him in the comments about the effects of changing to +45 offset on the wheels, let's see if he replies, it seems he will have that car for a while, so hopefully he'll give some insight!
    Meat Hammer and 360glitch thanked this.
  3. Bumflik
    Bumflik Senior Member
    Oct 26, 2017
    118
    91
    Philly
    Kinte
    TJ Wrangler . Sienna . Civic Type R FK8 '17
    Fenske is awesome
  4. yargk
    yargk Senior Member
    Jun 20, 2017
    365
    262
    SF bay area
    '18 Civic Type R, '16 GT4, '07 WRX wagon
    When changing from +60 to +45, you are changing from zero scrub radius to 15 mm scrub radius (more than half an inch). Torque steer is directly related to scrub radius.
  5. CTR1633FK2
    CTR1633FK2 Senior Member
    Apr 25, 2017
    562
    374
    Netherlands
    Civic Type R Fk2 base
    Electric Power Steering blocks most of the forces, so this increase in torque steer is not noticeable.
    jonnys_honda thanked this.
  6. baldheadracing
    baldheadracing Senior Member
    Jan 4, 2017
    1,081
    1,188
    Canada's capital
    Craig
    FK8
    #6 baldheadracing, Nov 19, 2017
    Really?
    The difference going from ET60 to ET45 was pretty freakin' noticeable to me in low traction conditions, but I did also change wheel diameter, rim width, and tire.
    What ET45 wheels are you running on your FK8, and what tires are you running on those wheels?
  7. CTR1633FK2
    Apr 25, 2017
    562
    374
    Netherlands
    I am comparing my ITR with my FK2. Much more feedback in the steering wheel of the ITR. FK2 steering feels numb and 'electric'.
  8. yargk
    yargk Senior Member
    Jun 20, 2017
    365
    262
    SF bay area
    I think numb steering and torque steer are different things.
  9. CTR1633FK2
    Apr 25, 2017
    562
    374
    Netherlands
    Not IMO. The feedback you get from the wheels to the steering wheel is the same. In case of torque steer it is caused by the drive axle. Normal feedback is caused by the amount of grip of the wheels/tires.
    So, if an electrical PS blocks most of the forces coming from the wheels, it will also block most of the forces caused by torque steer.
    If you look at the design of a regular EPS, you will understand why it blocks most of the forces getting to the steering wheel.
    In the ITR I could feel every change in offset and tire diameter. Both have effect on the scrub radius. In the FK2 the difference in steering feel is much smaller.
  10. CTR1633FK2
    Apr 25, 2017
    562
    374
    Netherlands
    An EPS also has an electronic torque sensor on the steering column. When a force is induced by the wheels in the direction of the steering wheel, the electric motor will counteract to this force. This torque sensor will also sense the force in the other direction. From steering wheel to the rack.
    Ideally, you would want some diode effect on this electric force. Only induce force when the driver is steering, but do not counteract on forces coming from the tires/wheels.
  11. jonnys_honda
    jonnys_honda Senior Member
    Mar 1, 2017
    1,850
    2,656
    Irvine, CA
    Jonny
    2017 Civic Type R #1288
    I feel zero difference with torque steer on my 18x9.5 +35 wheels installed on my FK8. And I have one track day down.
    Maybe my sticky tires help? Bridgestone RE-71R's :dunno:
    Ruckus thanked this.
  12. jonnys_honda
    Mar 1, 2017
    1,850
    2,656
    Irvine, CA
    Jonny
    To all who believe zero scrub radius trumps all... Please watch their video on the subject
    "A positive scrub radius tends to be beneficial while braking into a turn. A negative scrub radius tends to better for braking stability in the event of brake failure or split-mu braking. Typically the scrub radius is configured to be as small as possible to minimize the effects under braking, but squirm (from zero scrub radius) is also undesirable."
    Goal is to get close to zero. but not necessarily zero.
    yargk thanked this.
  13. baldheadracing
    Jan 4, 2017
    1,081
    1,188
    Canada's capital
    Craig
    FK8
    As would the lack of rain.
  14. yargk
    yargk Senior Member
    Jun 20, 2017
    365
    262
    SF bay area
    There's a difference between an EPS system filtering some intermittent forces (bumps) and counteracting something continuous like torque steer. Let's think about another continuous force, which is the "centering force" that brings the car back to straight driving. Turn into a turn at constant speed (constant speed is so that you don't induce torque steer because that's not what we are focusing on now), then let go of the steering wheel, you'll notice that you'll slowly stop turning and the steering wheel will slowly unwind by itself. This is due to the caster angle of the front wheels. It induces a continuous force that brings you back to straight ahead driving. If an EPS system counteracted continuous forces then you'd just keep turning right (or left) unless you physically pulled the steering wheel straight.
  15. yargk
    yargk Senior Member
    Jun 20, 2017
    365
    262
    SF bay area
    #15 yargk, Nov 21, 2017
    I don't think he actually says word for word what you quote. Quotations are different from paraphrasing so if you are doing the latter, don't use quotation marks.
    (edit: This was quoted from the description of the video, oops, but I think this description simplifies the matter a bit too much. I think the quote pulled below from the video is more useful)
    A direct quote from the video is: "The goal is to get it basically at zero or close to zero, a small amount can be helpful in emergency situations like this" And by small about he means negative scrub, not positive scrub (negative scrub on a CTR would be ET greater than 60!)
    I'd agree that in most cars zero-scrub isn't the most important thing and a few mm positive or negative could be fine. I have non-zero scrub on my WRX and my GT4. However, for a very powerful FWD car, zero-scrub becomes much more important because torque steer is stronger for more powerful FWD cars. Personally, I'm not interested in wheels that have an ET less than 55 mm for the type R. (which would keep the scrub radius less than 5 mm)
