No, they are adjustable for that reason. Too short is never really a problem. Generally, at it shortest, it still matches OEM length. The only concern with going to long is that you don't keep enough thread in the body and it rips out. Be sure to have at least 2-4 full turns in the main body for that.what happens if the front endlinks are set too short or too long? will it cause any damage?
If lowered on Sportlines, do you know how much shorter the front endlinks should be?No, they are adjustable for that reason. Too short is never really a problem. Generally, at it shortest, it still matches OEM length. The only concern with going to long is that you don't keep enough thread in the body and it rips out. Be sure to have at least 2-4 full turns in the main body for that.
Unless you have specific track or course you are tuning for I suggest just matching OEM to start with.If lowered on Sportlines, do you know how much shorter the front endlinks should be?
Yeah there's a problem with that lol, the endlinks that I received aren't adjustable to match the oem lengths.Unless you have specific track or course you are tuning for I suggest just matching OEM to start with.
Have a picture of them you can share? and part #.Yeah there's a problem with that lol, the endlinks that I received aren't adjustable to match the oem lengths.
That’s what I was afraid of. I didn’t find a chassis specific part on Pro Covic so I wasn’t sure if there was one. Do you know roughly how much distance should be between the top and bottom of the mounting points for my FK7? I’m only lowered on Eibach Sportline springs so it’s not an aggressive drop. Thanks Vincent!Ah I see, that's the universal kit that Whiteline sells. That is a universal part and you as the end user are supposed to cut it to length. That is not a chassis-specific kit which explains why it's not fitting how you are expecting. Whiteline make chassis-specific kits for our cars which is what we run and what I suggest.
What you want is part # KLC140-335
That is the true front kit for the 10gen.
Yes I got your email and I responded. Can you send the link for the other ones? I only see these for the Hatchback non Type-RWe do offer both options on our site: the one labeled "Not recommend for use with soft or factory springs" is in fact the Universal application, which we have verified to definitely work with coilovers / lowering springs. The other one labeled "Extra Heavy Duty" works with all spring types, but is a lot more expensive. This is the actual specific one for the 10th Civic.
I see we responded to your email as well. Let us know if you have any more questions at all.
