Which fuse to use for hardwiring dashcam?
w18abmsi
Davis
2018 Civic Si Sedan
I want to hardwire my Aukey dashcam with a 12V to 5V hardwiring kit and I want the camera to be on when the car is on. Which fuse spot am I supposed to use? Do I use the accessories (10V) fuse? I've seen people use the transmission fuse or one of the 20V fuses or one of the empty fuse spots. Does it make a difference?
It's my first time hardwiring a dash cam, so I'm new to this.
shoegazer
Raleigh NC
2018 Civic LX Coupe 2.0 (CVT)
Slot #29 in your chart feeds the cigarette lighter (accessory power) supply. You could use an 'add a circuit' pigtail from that slot and it will be on only when the engine is running or when the car is in accessory mode.
Synomenon
SW USA
2021 EX Hatch
Would both slot 1 and 29 be ignition controlled?
