- Dec 9, 2017
- 9
- 345
- 187
- Frisco, TX
- 2018 Championship White Civic Type R
- Banned
New owner. Looking to buy clear side markers. Can anyone recommend a site?
Hey how did it come out? Does water get in em?Thanks I ended up finding them.
I’ll look into the modification part.
Worked out fine with no modifications needed and no leaks. Only think you need to do is discard the JDM bulb plug and use the one that’s on the US version. To make things easier it’s best to unclip the harness to the plug prior to removing the side marker as it’s short.Hey how did it come out? Does water get in em?
The ones I bought came with led lights that fit stock plug. Didn’t have to do a single mod or throw awayWorked out fine with no modifications needed and no leaks. Only think you need to do is discard the JDM bulb plug and use the one that’s on the US version. To make things easier it’s best to unclip the harness to the plug prior to removing the side marker as it’s short.
What ones did you get?The ones I bought came with led lights that fit stock plug. Didn’t have to do a single mod or throw away
Right on! I wanted to keep it OEM. Did you go with the Depo lenses?The ones I bought came with led lights that fit stock plug. Didn’t have to do a single mod or throw away
Seriously I just bought like a $23 set off eBay and they worked out great. The led lights are weak but they light up the entire housing at night. Might have to wiggle it in to get it far enough to light up.What ones did you get?
Are these okay for type r though?Seriously I just bought like a $23 set off eBay and they worked out great. The led lights are weak but they light up the entire housing at night. Might have to wiggle it in to get it far enough to light up.
Ill message the seller and get back to you.Are these okay for type r though?
No they won’t fit because of the Rs fender flares.Are these okay for type r though?
The seller claims that they will fit type rs with little to no issuesNo they won’t fit because of the Rs fender flares.
"With little or no issue"The seller claims that they will fit type rs with little to no issues
