princemanfred
I just purchased a new Civic EX-T and absolutely cannot find any equalizer settings for the audio. Are there really just no settings or am I just not seeing them? Thanks for any help!
It's an algorithm that extracts center and surround information from stereo music. That is, any sound that's present in both the left and right channel equally should sound like it's coming from the center of the dash, so the algorithm can remove that from the left and right speaker and play it through the center speaker in the car instead to give a more centered sound for both front seat passengers. It also does some wizardry for figuring out what sounds should be played from the rear speakers to create a better sense of ambience/rear fill.Does anyone know what DTS Neural means? Is that some sort of wide array speaker system?
That's an interesting point. For a while I was running my new speakers off the factory amp, and I found that I liked DTS Neural better than I had with the factory speakers. One key difference: the factory center is a 3" mid, while my setup is a 4" mid and a 1" tweeter in the center. Much better reproduction of highs with the dedicated tweeter, so dovetailing in with what you said about the highs, that might explain why I thought it sounded better that way.DTS Neural works extremely well with music that emphasize highs more than lows. Go play Symphony Hall on Channel 76 and you'll know what I mean.
