What is your favorite gear
What is your favorite gear?
  • 1st: You are going to want to rotate those tires pretty often
    Votes: 2 2.0%
  • 2nd: If you don't hit a cone you aren't going fast enough
    Votes: 22 22.2%
  • 3rd: You spent how much on a helmet!?
    Votes: 50 50.5%
  • 4th: So you are missing your cousin's wedding to spend the day at a track?
    Votes: 13 13.1%
  • 5th: GT cruisin'
    Votes: 3 3.0%
  • 6th: Eco mode?
    Votes: 3 3.0%
  • Neutral: You don't understand Ferris, he doesn't drive it. He just rubs it with a diaper.
    Votes: 2 2.0%
  • Reverse: If you tell the cops where the bodies are I'm sure they won't give you the chair
    Votes: 4 4.0%
  • Total voters
    99
.grimace
Byron
Reno, NV
2021 Honda CTR, 2022 Range Rover , 1990 CRX SI
I would like to see 3rd gear option changed to "3rd: Hitting that 3rd gear vTeC"
Then I'd vote :p
ShaRm3064
Sharmilan
Toronto Canada
2017 Honda CIvic Type R #3064 Crystal Black Pearl
3rd gear FTW. Its like its on a boost-by-gear protocol and just hit warp speed compared to 1st and 2nd.
R-10552
Russ
NJ
2021 Acura RDX Aspec, 2019 Civic Si (wife's)
3rd gear is my favorite in any Honda/Acura I"ve owned.
neveronline
Clayton NC
Current '19 CW CTR #23856 & '18 Accord 2.0T Previous - 2015 WRX, 1999 SI, '04 S2000, '08 Evo X, '10 SI sedan, '11 Fit Sport, '11 WRX, '13 ILX
3rd is my favorite but due to speeds reached at the end of it I usually only get to wring out 2nd ;)
tinyman392
Marcus
Illinois
'18 Civic Type R (RR)
2nd gear pulls are fun. Especially on rural streets. Pull out of a light in first and get up to about 15MPH, shift into 2nd gear, ease it in to about 20-25 then smoothly get to full throttle that tops out around 55, right at speed limit. Granted most people tend to like 3rd gear more.
cococly
2018 Rallye Red Honda Civic Type-R
I love 6th gear. I put mine into 6th gear at around 60kph.
I know it isn't recommended by Honda, but it felt fine, no shake, and if I need power, I put it back to Third.
tinyman392
Marcus
Illinois
If I'm at cruising speed and just trying to keep a constant speed I will do 6th gear at 40MPH (63KPH). If I need to go, I'll block shift myself to 4th (puts me right around 2500 RPM). I personally don't feel like it damages anything since it shouldn't lug the engine. I didn't know it wasn't recommended by Honda tough, what's your source on this?
RedGiant217
Indiana
2001 Honda Accord
Haha I'm the only one that loves first gear?
Get that pedal modulation just right and it'll scare a first time passenger before hitting 35mph. :D Just don't hit the rev limiter and embarrass yourself. :oops:
tinyman392
Marcus
Illinois
I hit the rev limiter for the first time today, but in second gear. It was embarrassing :(
Edit: getting the optimal power down in 1st (without skipping) does take a little finesse, you kind of have to build into it just right. Takes time to learn, even longer to master.
RedGiant217
Indiana
2001 Honda Accord
Haha I hit the rev limiter the first time I was trying to show a buddy how fast the car is. It's bound to happen if you're not paying enough attention to the dash. 7000RPM comes up quick.
xbbnx
Houston TX
2022 Si, 2017 Si (past), 2015 Si (past)
What speed does 2nd gear top out at?
