What is Knock Count and Knock Control (defined)
Vincent@27WON
REDEFINE the Aftermarket
Vincent
Las Vegas, NV
www.27won.com
I wanted to share this great piece of information from Derek at IMW. He created this comment in a Facebook group and it contains solid info that is worth re-posting and sharing. So check out these useful definitions and come back for more.
Thanks D-Rob
"Knock Count" = This parameter is a reflection of the ECU's misfire monitor. It is NOT an accurate reflection of anything other than misfire events. When will you see these normally? Startup, rapid throttle closures, rapid throttle inputs, rapid release of the clutch pedal, and sometimes at idle (especially if you have a lighter flywheel/clutch combo, and/or plugs that have been gapped down to prevent spark blowout at high load). A completely stock car, operating perfectly will still accumulate these counts. In my experience with these engines, you will see more activity on cylinder four compared to others, as the crank position sensor is physically located closest to there on the block. This usually isn't a concern area unless you see a steep count in a very, very short time (like 50+ in a few seconds), which will likely trip a P0300-variant DTC code.
"Knock Control" = This parameter is the ECU's determination of fuel quality. Movement here indicates the knock sensor hears what it thinks is knock activity, and reports to the ECU to apply a steeper ignition retard to avoid continued knock activity. This value is dynamic, and WILL move from time to time. On Civic Si models, there doesn't seem to be a forced rise at play at WOT like the non-Si 1.5T ECU's (which naturally rise above 5,200-5,400rpm regardless of sensor input). Movement that goes up and up and up and never comes down is more concerning than movement alone. Knock control can typically be manipulated down by driving the car in a higher gear at lower engine speeds and targeting atmospheric pressure on the MAP sensor reading.
Nostake
jeremy
kalispell MT
2018 Aegean Blue Civic Sport Hatchback
Thanks D-Rob
What knock would you expect on 91 octane? i use 91 and have the race maf and custom tune and my knock is around .59 i read that .49 is where it should be?
Readings in the mid to high .50's on 91 octane is about what you'd expect. With 93 octane, .49 is the lowest you'll see.
Deleted member 26142
Thanks D-Rob
This info is much appreciated as it puts my mind to ease, I have noticed that around 5,000-6,000 rpms kcontrol does rise to about .70-.80 on a WOT pull even in perfect ambient temperature running 92 Oct. But it does go back to .49 when I take it easy again and just cruise
amyisquiet
Amy
US
civic fc1
Thanks D-Rob
On non-SI, above 5200-5400RPM, will "Knock Control" rise naturally? If it continues to be above 5400 RPM, will "Knock Control" rise indefinitely?
amyisquiet
Amy
US
civic fc1
Thanks D-Rob
Hondaman248u
Delaware
2018 sport touring
hi guys i just installed a 27won w1, a mishimoto intercooler and charge pipe, a prl catted down pipe, a megan front pipe, and a prl trans cooler. I have never seens my knock control go this high. Also my afr was spot on staying around 14 + - . i never took the car out i just let it idle cause i gotta check the trans fluid tom and i havent got the bumper back on so its still on jackstands. let me know something please
  • Like
Reactions: Myx
Myx
Delaware
You have never seen your knock control go how high? How high does it go and under what conditions? Wide open throttle for a few seconds and what does it do?
Nice setup you have btw.
Joe1986
joe
hamilton
Honda
Thanks D-Rob
Hi what Facebook page is it,
Hondaman248u
Delaware
2018 sport touring
sorry I was worming up my car adding coolant after the install and looked at the v2 and it was at 1.30 it used to sit at like .49 and this was just at idle sitting cause its still on jack stands until I get the bumper and the plastics underneath put back on
BrianAngel702
Brian
Las Vegas
2020 Honda Civic 1.5T
[/QUOTE]
Great share Vincent? +(Derek) ?
(I still want my free exhaust JK)
My K.Count is 43605... Lol
Honda Civic 10th gen What is Knock Count and Knock Control (defined) 20210419_040419
Living on the west coast refineries are not producing 93 octane but yet most tunes are set up for that. You can use a fuel calculator to add 100++ to balance your fuel to 93 octane but be careful, running too high of octane will cause your motor to run very rich in these Earth Machines.. ?
D-Rob LOL remember my 8 mpg nightmare.
Honda Civic 10th gen What is Knock Count and Knock Control (defined) IMG_20200925_072658_772
Anyone anyone want to buy a Civic LOL
Honda Civic 10th gen What is Knock Count and Knock Control (defined) 20201018_142545
Old School B
I.G. @Staged.FK7
Honda Civic 10th gen What is Knock Count and Knock Control (defined) Polish_20210417_172929496
Saablife
Zachary
Pennsylvania
2019 Honda Civic Type R
Hi guys!
I know this is talking about non-tyoe r's, but I wanted to make sure I understand correctly that Type-R's don't have knock control values since it isn't tracked over time? So we can't really monitor knock?
