Weight reduction for the FK8
  1. OP
    wassen
    wassen Senior Member
    Nov 12, 2017
    185
    127
    Sweden
    Philip
    CTR 2017, Volvo V70
    Thnx!
  2. Night Fury
    Night Fury Senior Member
    Jun 13, 2017
    986
    685
    Chicago
    Black Type R
    Thanks Man!
  3. Estoril4
    Estoril4 Senior Member
    Jun 30, 2018
    153
    86
    NC
    2018 Hatchback Sport Mt, 2017 Toyota 4runner XP, 2014 Audi S4, 2017 CBP Type R
    Tend to believe that the only thing truly worth it and noticible for a DD is reducing unsprung. However at the same time you must be sure that you aren't altering the suspension geometry enough in doing so to offset any benefits gained if that makes sense. Maybe reducing battery weight and a titanium exhaust/dry carbon fiber paneling($$$). I'd be surprised to see if someone could get in the 2ks with a driver, much less with a passenger to mutually enjoy the lighter weight without completely mangling the car. As stated before you're almost better off going on a diet lol
  4. remc86007
    remc86007 Senior Member
    Mar 18, 2018
    436
    284
    Jacksonville, FL
    Ryan
    2018 Civic Type R
    I've had that happen to me on the street two times. Both times I was taking a 35mph recommended speed exit ramp at 75mph right after the fuel light came on...
    .grimace thanked this.
  5. Number 215
    Number 215 Senior Member
    Nov 24, 2018
    175
    Virginia Beach, VA
    Jason
    2017 Honda Civic Type R
    Man, Seibon has soooo many carbon fiber parts for our car now ! When I win the lottery or became ruler of a country or figure out how to sell people regular air for thousands of dollars per bottle, I'm definitely gonna buy one or two pieces lol
    Just be careful out there people. Some wet CF parts are even heavier than OEM !
  6. Solis#1730
    Solis#1730 ScarFace#1730
    Mar 22, 2017
    426
    448
    Miami
    Civic hatchback
    This is the weight with and without me in the car, full tank of fuel and FBO no other weight reduction 55C1034F-EC0F-47F3-8974-82428AEB6C3B.jpeg 6398D902-4079-47CF-AF7D-88BA24462320.jpeg
    Myx, wassen, [email protected] and 4 others thanked this.
  7. scottjua
    scottjua Senior Member
    Jan 5, 2019
    54
    38
    Plano, TX
    Scott
    2006 Subaru STI, 2019 SGP Civic Type R
    For those looking for a lighter weight battery, but want daily driver reliability, check out the Odyssey PC925.
    I've been running these in my STi for about 10 years now with no issues. Getting 3-5 years of life out of each. No problems with TEXAS cold mornings, etc. until they start to run out of life.
    Not a featherweight battery, but a lot lighter than most full size batteries.
    Make sure you check for your correct pole positions (+/-) and get the posts for the terminals... but here's a general link:
    https://www.amazon.com/Odyssey-PC92...WA6YAXFMY0KRQVFY6A7T&qid=1551498647&s=gateway
    Meat Hammer and wassen thanked this.
  8. .grimace
    .grimace Senior Member
    Nov 9, 2017
    1,139
    759
    Occupation:
    Web Design
    Reno, NV
    Byron
    2017 CTR, 2014 911 4S, 2019 Range Rover, 2014 F-JuanFitty
    @Night Fury ever figure something out? Someone liked one of my posts and made me look at the thread again. I still haven't just because I never had good experiences on past cars with smaller batteries
    Night Fury thanked this.
  9. b534202
    b534202 Senior Member
    Jul 3, 2019
    74
    19 CTR
    #114 b534202, Sep 18, 2019
    Things that I didn't see mention in this thread:
    Horn: reduce down to 1. Cost: free.
    Remove the brake rotor backing plates. I don't know if those are welded on or bolted on, but either way they can go. Cost: free.
    Stainless steel brake lines might be lighter than OEM rubber ones. I just changed it on my other car and it is lighter. Cost: ~$150
    Use zip tie to secure those light weight batteries. Whatever battery tie down you buy would still be heavier than a zip tie. Won't pass tech inspection if you track or autocross though. Cost: 10 cents.
    Don't carry a full tank of washer fluid.
    Meat Hammer thanked this.
  10. remc86007
    Mar 18, 2018
    436
    284
    Jacksonville, FL
    Ryan
    2018 Civic Type R
    I'm with you other than the zip ties. I don't think most zip ties are made of plastic which can withstand being heat cycled repeatedly.
  11. .grimace
    Nov 9, 2017
    1,139
    759
    Occupation:
    Web Design
    Reno, NV
    Byron
    Nor would I want to trust it even on the street. I've seen what happens when a battery hits both terminals on the frame. Not pretty
  12. b534202
    Jul 3, 2019
    74
    19 CTR
    That's fair. There's a reason why that doesn't pass tech inspections :p
  13. Night Fury
    Jun 13, 2017
    986
    685
    Chicago
    Black Type R
    Mine is been place with the stock tie bar on top of extra insulation, works fine.
    I just saw this.
    jetydosa and wassen thanked this.
  14. 123sillyboy123
    123sillyboy123 Senior Member
    Jun 3, 2018
    806
    210
    Markham, Canada
    2019 CTR, 2018 Honda HB sport
    anyway know how much does OEM exhaust weight?
  15. ipeefreely
    ipeefreely Senior Member
    Jun 5, 2018
    461
    644
    Bay Area
    Will
    2017 Ford Raptor / 2017 Acura NSX / 2019 CTR
    THis is what I'm running. The only issue I had was the fact that the battery dies when you don't drive the car for more than a week. I got around that by buying a Ctek battery tender.
