repeet
- Jun 3, 2017
- 16
- 698
- 694
- Fort Mill, S.C.
- Website
- jesus7feasts.fyi
- '23 BRZ
On one of the other threads someone mentioned that once the ambient temperature exceeds 75 degrees, that our engines start pulling timing and boost. I find that very discouraging.
There are many threads about wrapping intake components and heat shielding, but no one seems to have had much success.
All most of us are looking for, whether through CAIs or engine compartment venting, is the nominalization of manifold air temperatures.
So I started thinking about water-meth injection. There are several people here on this forum that have successfully installed water-meth injection systems. Which they used to push their engines to the point of destruction. A bad association of subjects.
Why can't somebody design a water-meth injection system that would simply keep the intake air temperature to the level that would normally be seen on a nice 70 degree day.
That way, even if you were in southern Texas on a 101 degree day, or the Midwest on a sweltering 95 degree day, we could get a consistent level of performance all year long.
If properly adjusted, it would never kick on during the fall, winter, or spring. Some regions would use the system for longer periods, but we would all have a uniform level of performance. The cost should be well under $1000.00 based on what's available currently. The trick would be in the controller.
Mods would then be utilized to their greatest potential, as a stable combustion chamber temperature could be guaranteed.
