Wallpaper
  1. Fredwithanf
    Fredwithanf Member
    Apr 6, 2018
    Okemos, MI
    Fred
    18 Si Sedan
    Can anyone help? I've tried everything here and I just can't seem to get the system to see the photos (jpg) on the USB stick.
    Here are a couple of things I've already tried to do.
    • Reformat stick to FAT32
    • Adjust image size so they're below 1.5MB with a short edge less than 1080
    • Renamed photos to short name
    • Tried both USB ports
    • Confirm in advance (Android) menu that the storage device is showing up
    • Tried to upload via clock menu as well as the gallery
    I've seen that there are some image size requirements but does anyone know if there is a ratio requirement as well?
    The only other troubleshooting step I can think to do is to download one of the clock image files people have uploaded to see if any of those will work. Maybe there's something wrong specific to my images that isn't working correctly.
  2. Fredwithanf
    Fredwithanf Member
    Apr 6, 2018
    Okemos, MI
    Fred
    18 Si Sedan
    Welp... I tried one thing different and that seemed to make the difference. I was previously using a 64GB USB 3.0 stick but then tried the same photos on a 16GB USB stick. Worked just fine.
  3. dick w
    dick w Senior Member
    Oct 26, 2015
    1,948
    853
    Kapaa, HI
    '16 Civic Sedan Touring (MSM/GR), '18 CR-V Touring AWD (BRPII/GR)
    Hmm. Wondering if it's a stick-specific compatability issue. I've used both Lexar USB 3.0 (sad they passed away--I really liked their Firefly and S45 sticks) and SanDisk USB 3.1 128GB sticks without problem.
  4. Jefhaugh9
    Jefhaugh9 New Member
    May 14, 2018
    Herndon, Va
    Jeff
    2017 Civic Touring
    I'm having the same issue. I've used a 64GB exFAT and 4 GB FAT. The car doesn't seem to recognize them. Any ideas?
  5. n2da2nd
    n2da2nd Senior Member
    Mar 23, 2018
    783
    666
    Occupation:
    Systems Engineer
    DFW
    Nam
    2018 Civic Hatchback Sport Touring, 2011 Honda Pilot EX-L
    I just recently tried the usb hub but our car wouldn't support it.
  6. Jefhaugh9
    May 14, 2018
    Herndon, Va
    Jeff
    2017 Civic Touring
    I finally got it working, wish I knew how. I put the pictures on the same exFAT32 64Gb card as my music. No luck with the wallpaper. I then did the clock wallpaper and it worked, the then regular wallpaper worked.
  7. Jefhaugh9
    May 14, 2018
    Herndon, Va
    Jeff
    2017 Civic Touring
    I think I figured it out but it's really wierd. I was only able to see the jpgs on the jump drive when I was playing music from it on the audio system. Go figure.
  8. wolfman987
    wolfman987 New Member
    Sep 18, 2018
    Illinois
    2018 Civic Hatchback EX
    Anyone got the wallpaper for that first comment with the red Honda logo?
  9. CIVIC BIGUS
    CIVIC BIGUS New Member
    Sep 26, 2018
    Tf10 7er
    Civic
    I'm trying to load my own wallpapers through the android gallery - where you would load the inbuilt wallpapers or live wallpapers. However, it wants me to crop the picture. The crop screen comes up, but there's no way to save after you've selected the crop area. I've used the recommended size and I can use them on the home screen, but I really want them behind my music screens. Have looked everywhere and can't find a solution. Any help would be very welcome indeed.
  10. bchauvfk7
    bchauvfk7 Senior Member
    May 21, 2018
    63
    Occupation:
    Retail
    Louisiana
    Blake
    2018 Civic Sport Hatchback
    #40 bchauvfk7, Sep 29, 2018
    Images are all set to size; tried one at the lowest and highest pixel ratio in a completely empty flash drive. With just the ignition on and audio off, my "import image" option isn't available. Any ideas?
    -2018 Sport hatch
  11. dick w
    Oct 26, 2015
    1,948
    853
    Kapaa, HI
    One thought: are you running the "modern" skin or whatever they call the alternate one?
  12. bchauvfk7
    May 21, 2018
    63
    Occupation:
    Retail
    Louisiana
    Blake
  13. dick w
    Oct 26, 2015
    1,948
    853
    Kapaa, HI
    Aha. Not "Display Audio". My theory is no good then. In '16 Sedans with Display Audio, IIRC, the alternate skin and user wallpapers don't mix. Hopefully somebody else has a better answer for you. Sorry.
    daBiker68 thanked this.
  14. bchauvfk7
    May 21, 2018
    63
    Occupation:
    Retail
    Louisiana
    Blake
    The one thing I didn’t do was check the format of the usb. ‍♂️
    BarracksSi and dick w thanked this.
  15. daBiker68
    daBiker68 Member
    Jul 4, 2018
    Eastern Passage NS
    2018 Civic LX - Lunar Silver Metallic 2017 Subaru Forester - Quartz Blue Pearl
    I have discovered the solution to a lot of the display and audio problems that we are seeing... Ready for it? here it is!!!!
    Use a brand name USB 3.0 Stick.
    Yes, that's it. Don't use a micro SD with an adapter. Don't use a cheapie knock off you got on eBay for $1.99 with free shipping.... a true USB 3.0 thumb drive will allow you to be able to see that menu for uploading wallpaper files into the Civic's memory, and it will also allow audio uploaded to that stick to start from where the last song stopped. I don't know if Honda meant for this to be the case, but it seems to be consistent.
    This might be a harder one to believe, but the USB drive might also be responsible for some of the head unit problems that are out there (freezing, black screen, etc). I had a 3.0 in the cupholder area that I whacked with a large refillable water bottle. Didn't seem to do much at the time, but started noticing head unit issues soon after. I was going to mention it to the dealer when I brought it in for the next maintenance, but decided to try both reformatting the USB (didn't help) and then replacing it with a new 3.0 class - voila! no more freezing head unit, unplayable songs, duplicates in the song list....
    at Best Buy in Canada, you can get a 16GB Kingston DataTraveler (model 100 G3) for about $8, if memory serves me correctly...
