charleswrivers
- Charles
- Nov 3, 2017
- 43
- 3,736
- 4,468
- Kingsland, GA
- '14 Odyssey, '94 300zx, 2001 F-150
- Vehicle Showcase
Yep, that and the base 11 vanes have a sharper torque spike down low compared to the 9 vane the Si has.As an Si owner, I think you have a lot less to worry about as compared to the "base" 1.5T owners. Si motors are being pushed harder and I've yet to hear about one ending up with mechanical issues.
I'm hoping for some traction on someone doing a comparison of the rods. I'd do it myself but I don't have a set of calipers and that's just one more thing to buy. Rather chip in towards someone who has a set.
Thinking N/A... at low RPMs, an engine doesn't need many CFMs. Generally, anything I've seen has a pretty linear rise in CFMs as you raise RPM as the engine is just like an air pump. It isn't perfectly straight but it's close.
With this little turbo stock, you can slam in a HUGE amount of air for a relatively low RPM and make HUGE torque down low. As the top end though, the engine actually really needs some CFMs and the little turbo is tapped out. The base is even worse than the Si. You can hide it a little with a better intercooler but by having a larger volume to compress air in you're going to gain a little lag in the process.
Of all the mods out there, second maybe to Ktuner/Hondata itself... this and any big turbo stuff on the horizon is the most exciting stuff to me. Anything that's making the power up top higher is *really* what is making this car fast. 300+ ft/lbs of torque down low with horsepower falling out badly up top isn't going to make a fast car. *This* is awesome... and bang for the buck for an easy swap, tune and go is probably unbeatable.
