Featured VitTuned Drop In Turbo Upgrade -- Initial Results Sneak Peak!
Thread Status:
Not open for further replies.
  1. VitViper
    VitViper Senior Member
    Apr 28, 2015
    638
    1,975
    United States
    Lots
    #1 VitViper, Dec 5, 2017
    Well this has been in the works for some time and we finally have a decent "drop in" turbo upgrade for the 1.5T! The goal was to have something quick and easy to install and pick up 10-15% power and keeping the powerband from dropping like a rock after 5000 rpm.
    Mission accomplished.
    Get it here: http://www.civicx.com/threads/vittuned-1-5l-stage-1-turbo-upgrade.19564/
    Foremost, it's sad, but I have to put this disclaimer in: my dyno is not very generous. A car that dynos 270-280whp here will trap 108-109mph (@maddmatt02 's car made 230-240 here and traps 103-104mph). None of this sub 300whp and 104mph traps. However if you need your glory #'s, just multiply by 1.15 on what you see.
    First -- we have the results w/ the turbo upgrade on 92 octane vs E40 fuel. I did also go up as high as E60 fuel and NO MORE POWER WAS FOUND. The motor, yet again, for the countless time, was happy in the E40 range. What WAS found at this power level on E60 fuel were misfires and aircharge blow out due to the injector pulsewidth being too high (not enough time for the fuel to tumble/mix). We also target a conservative 11.2-11.3 AFR on 92 octane and 11.8-12.0 afr on ethanol blends, not 13.2-13.5 (which some people do to reduce the fuel demand on the D/I fuel system -- this doesn't make power, creates heat and doesn't make you "faster" when you put the motor through it's paces -- turns the ethanol into a blow torch).
    For the stock turbo graphs you can see I extrapolated the dyno chart with a line -- we don't dyno the car past 6500 on the stock turbo as power loss is DRASTIC up there.
    312whp on E40 and 276whp on 92 octane. And the best art -- power carries to 7000 rpm! No more cliff dive after 5000 rpm.
    How's this compare to E40 on the stock turbo?
    This is going all out on the stock turbo -- as you can see we removed the huge torque spike below 3500 rpm (harder on the rods). Torque comes in smoother and power from 3700 to 5000 rpm is basically a wash -- but then the upgraded turbo continues to carry. Anywhere from 20-40whp gained and now it's got some legs!
    How's this look on 92 octane? Let's compare a conservative tune first.
    Plenty gained over a conservative tune.
    How about a really aggressive 92 octane stock turbo tune that pushes the knock limit (which people like to do for "glory" numbers, but unrealistic to run as it gets crunchy and can hurt the motor. Hey we do it for fun too!)
    Similar results as the eblend.
    Overall the results are satisfying and the car pulls MUCH better instead of just being a peaky torque hit. This should also allow you to make more power however you chose to run the motor -- pump gas, corn, conservative, aggressive, whatever. As it sits now the restriction is in the turbine size of the turbo -- which I chose not to change as I did NOT want to impact spool drastically (and as you can see we didn't lose much). Upgrading the turbine wheel may be in the cards as well, but to make more power with it we'll have to look at moving away from ethanol based fuels and step up to race gas to lower the demand on the fuel system -- something most people don't want to do due to the increased cost of the fuel.
  2. FKSE7EN
    FKSE7EN Senior Member
    May 11, 2017
    557
    560
    2017 HatchBack Sport 6MT
    This is huge! Great job as always Vit!
    andyboyd102 thanked this.
  3. OP
    VitViper
    Apr 28, 2015
    638
    1,975
    United States
    Lots
    Just to show you how well this bad boy is working 8)
    LilToTo17, Lume80, Matt Noke and 5 others thanked this.
  4. AsianGuy98
    AsianGuy98 Senior Member
    Apr 20, 2017
    720
    386
    Illinois
    2017 Civic Si Sedan
  5. andyboyd102
    andyboyd102 Senior Member
    Dec 15, 2016
    534
    501
    Occupation:
    Transmission Power Grid/ Southern Company
    Alabama
    2017 Si
    I can't wait for this to come available. Once again you show why you are leading the way on tuning options and R&D work for us 10th gen owners. Hats off to you and thanks for sharing your hard work for us users wanting the best product and best available tuner.
    Lume80 and FKSE7EN thanked this.
  6. 17siturb0
    17siturb0 Senior Member
    Dec 3, 2016
    1,319
    818
    Occupation:
    Health Care
    U.S North east
    2017 civic si sedan, 2006 civic si coupe
    Definitely plan on ordering this when available. Thank you sir! :respect::drive:
    JDM_DOHC_SiR thanked this.
  7. FKSE7EN
    May 11, 2017
    557
    560
    @VitViper since this is a compressor wheel upgrade would you recommend using a core from an Si/CRV for a base 1.5T?
  8. davemarco
    davemarco Senior Member
    Jun 3, 2017
    1,876
    1,063
    New York
    2019 Civic Type R (CBP), 2001 Honda Prelude (Premium White Pearl)
    Any concern over connecting rod failures running over 30 Psi of boost and more torque?
  9. OP
    VitViper
    Apr 28, 2015
    638
    1,975
    United States
    Lots
    Boost pressure is irrelevant. Torque breaks rods. HP = torque * rpm / 5252. We've reduced the peaky torque and instead "moved" the power band up to make more HP. So if anything it'll live longer at this power level.
    Using the Si turbo as a core is highly recommended as exhaust pressure is a serious issue after ~18-20psi. I expect EMAP to be even worse on the base turbo.
    Scarlet, simon_lefisch, 17siturb0 and 3 others thanked this.
  10. davemarco
    Jun 3, 2017
    1,876
    1,063
    New York
    Was the 277 whp on the new turbo with a more conservative tune? If so, what would an aggressive tune on the new turbo net with 92 octane?
  11. OP
    VitViper
    Apr 28, 2015
    638
    1,975
    United States
    Lots
    Kind of in the middle -- roughly the same as the conservative stock turbo below 6k but a little more aggressive above that since the turbo is still doing work.
    LilToTo17 and davemarco thanked this.
  12. davemarco
    Jun 3, 2017
    1,876
    1,063
    New York
    Whoa! So if I'm interpreting correctly, that means that this new turbo could make even more power on 92 if it were pushed harder below 6K!?
  13. davemarco
    Jun 3, 2017
    1,876
    1,063
    New York
    Did you feel there were any issues with less aggressive daily driving, with the power curve pushed out ~500 rpm and less low end oomph? Sorry for all of the questions, just really excited.
  14. OP
    VitViper
    Apr 28, 2015
    638
    1,975
    United States
    Lots
    On 93 octane for sure. 92 octane I wouldn't push it harder.
    No it still has plenty of torque to pass in 6th gear... I should lay it over the stock dyno pull... still makes more power than stock.
  15. JDM_DOHC_SiR
    JDM_DOHC_SiR Uncle Dave
    Apr 17, 2017
    926
    1,051
    Occupation:
    Government
    Chula Vista/ Eastlake
    2012 Acura TL Califonia Edition / 2018 Civic Si Coupe
    YES!!.... More money to blow:headbang::banghead:
Thread Status:
