rjvanro
Hiya Civic Fans,
The Aug. 15 hatchback news release mentions "sport-tuned electronic power steering with variable gear ratios" This is worded differently than the coupe description at honda Canada's website which says "Variable Ratio Electric Power-Assisted Rack-and-Pinion Steering (EPS)"
Is there any chance the coupe and hatch are set up differently? Would this system be similar to the system put into the S2000 as described in the post (found on wiki) below? Thnx.
The VGS system, which will debut in the S2000 type V, varies the steering gear ratio continuously according to vehicle speed and steering angle to provide a heightened "joy of maneuvering." The adoption of this variable ratio system ensures ideal handling performance through a broad range of driving conditions. Agile and exhilarating performance is especially noticeable on winding roads, since the front end of the vehicle turns sharply in precise response to driver steering input. While cruising at high speeds on expressways, the VGS offers a smooth and progressive ratio setup without excessive sensitivity, providing the driver with the relaxed and reliable driving feel of conventional steering systems. Astonishingly, the lock-to- lock ratio* is almost halved to 1.4 turns for better maneuverability in the low speed ranges.
