rajahdat
- Nov 30, 2017
- 11
- 87
- 85
- SouthWest
- 99 nevermind
A simple upgrade for the CTR ground wires. 3 Raychem heat shrank grounds. 1 engine, 1 transmission, and 1 battery ground replacement.
Installation is straight forward and there are no instructions. With simple tools, you can do this at home with time and patience.
Battery replacement is straight forward. The other 2 grounds require removal of other parts to gain access to its respected areas.
Overall quality 10 out of 10, as Eli supplies the HPD team with replacement grounds.
Pricing is $75 for the Raychem set. There are cheaper options but I can’t quote the prices as they may have changed.
Contact Eli in the NA owners’ group should you be interested in purchasing a set.
As for performance, minuscule only to electrical components. It does provide a better ground without a doubt and overall if you plan to keep your “R” long-term it’s a good upgrade to look into. The stock grounds are made with production in mind meaning in time they may become brittle with time.
