Type-r front Subframe brace
Captaindicki
Ontario
2018 Honda Civic Si Coupe (sold)
Hey do the 2 bolts attaching the brace to frame need threadLock?
KYRGYZ
Bay Area
16 Civic LX, 18 Model X 100D
all parts stores say 50290-TGN-E00 part is discontinued... any one know if updates is available or no?
bahndrvr
Trevor
Melbourne, Fl
2017 Civic Si White Orchid Pearl, 1983 Foxbody 4 eye Notchback
I didn’t use thread lock, have had in car for over 10k miles now with no issues just torque it to spec.
CanadiaegeanBlue
Humza
What are the correct torque specs?
Just ordered it as well. $16 + $8 for shipping :)
Also coming are the following: Acuity short shifter (already have cable bushings + pedal relocator), Ultra Racing front strut brace, 4-point trunk brace, and Eibach Swaybar with Accord Endlinks. Going full monty on this one, I can't wait to go on the first drive, and be blown away by everything!! :headbang:
Thanks_Enjoi
Pennsylvania
18' SI Sedan
I have everything acuity makes but the short shifter upgrade itself, along with the ultra front and rear tower, cusco RMM. I just ordered the cusco rear sway and accord endlinks. Your car will feel much better.
CanadiaegeanBlue
Humza
Your are hyping me up!! I made the mistake of taking out my friend's Cayman GT4 for a rip, and ever since then I've been craving just to get my car to feel 1/4 the way how dialed in that GT4 is in stock form. Forbid I drive a 6-speed GT3, I would totally go full racecar with my Si! :doh:
CanadiaegeanBlue
Humza
Update: I got the UR Trunk Brace, 27Won mount, and Type R subframe brace installed, and the results are awesome! The chassis feels way more buttoned down - pending install are the UR Strut Bar, and Eibach RSB.
MEESE15T
Bret
muskegon,michigan
2018 Civic HB Sport
Then to more closely emulate the balance of the Type R, one would need both this front brace and a front sway bar?[/QUOTEYour car already has a front and rear sway bar this is a part honda puts on the type R,and not on the rest of the civic line
MEESE15T
Bret
muskegon,michigan
2018 Civic HB Sport
Can someone who installed this comment please? I want to retain all the under body plastic.
So the Type R swaybar aluminum endlinks also fit our SIs? Wonder what else.
All the underbody plastic fits just like it should,you won't know the brace is there.
bluehatch17
bluehatch17
NJ
I ordered two sets of these. Just installed on my 2019 coupe sport. Both times, parts were not backordered. Note with the 2.0l engine.
You have to get pretty deep towards the middle of the car. Besides the oil change under panel. You have to remove 4 black 10mm bolts, and also 4 black plastic clips. 2 of the clips are in the wheel well area. (This is for my coupe, I have not installed this on my hatchback).
You probably can do it without taking off the oil change panel, but I find it gives the rest of the black underpanel more flexibility to move around. You definitely do not have to remove the larger black one. The oil change panel is silver.
Honda Civic 10th gen Type-r front Subframe brace 3310C8FB-1E93-4E71-B4C1-CCC4834D06EE
Honda Civic 10th gen Type-r front Subframe brace E3DA4A59-B49B-4600-B19B-1B1329F89CE4
bmaf55
Brian
NY
2018 Civic SI sedan
Anyone have a link to the accord endlinks? Do they come in a pair or you have to get 2? Thanks!
Matthyahuw
Matthew
Valley of the Sun AZ
2018 Agean Blue Civic Si Sedan 2016 Omaha Orange Jeep Renegade Trailhawk
Accord rear end links P/N 52320-TLB-A00
MOOG now has their end links out, but they've been perpetually out of stock
P/N K750874 (rear)
Bosco72
Albert
New jersey
2019 Civic coupe sport
Mine finally came in hopefully the 2019 sport coupe 2.0 has the threads already
