Turbo/engine problems
  1. Fk8Frank
    Fk8Frank New Member
    Jan 13, 2020
    Chicago
    Frank
    2018 CTR #18932 , 2000 civic ex , 2007 BMW M5
    Hey guys, I have a 2018 CTR and I put a Perrin intercooler and a AEM intake on it recently and it’s been doing wonders and I recently had it in tuner galleria chicago and I had to disconnect the battery. After I redid the battery to leave I noticed it had a lot more power to it and now today I was driving home and did a slight pull in R mode and then the check engine light and emission and rev match system lights came on. Went to a shop and had them scan but they half assed it and said it was the MAF sensor. I check it out and saw the wire to my maf sensor is a little frayed so I wonder if that’s the problem? I’m not making a single pound of boost and I’m just worried I blew the turbo.
  2. Funnyguy2000
    Funnyguy2000 New Member
    Mar 15, 2020
    01465
    Michael
    2017 honda civic si sedan
    It happened to me too in my 2017 honda civic si all lights on no boost and when rev and go down it almost died out after put prl innercooler and cold intake
  3. Shankmeyster
    Shankmeyster Senior Member
    Mar 15, 2017
    2,913
    1,379
    AZ
    2020 Civic Sport Hatch
    Did you check for boost leaks? I'd get an OBD scanner and see what's coming up.
    Fk8Frank thanked this.
  4. Hollywoo0220
    Hollywoo0220 Customer Service oriented (most of the time) :-)
    Feb 10, 2019
    647
    437
    WA
    RJ
    Tank, Lunar Module, and 1990 Diahatsu Charade
    @Fk8Frank
    If your MAF wire is “frayed” (as you say) then, your ECU is unable to register the Air Volume IN to apply correct fueling - thus No Boost.
    That’s your first trouble shoot.
    2nd would be to ensure your Intercooler Hoses are FIRM and tight at the lower connections.
    But wiring can cause what you are experiencing.
    You would need to overboost your turbo quite a bit to blow it out - I would not ascertain that happened.
  5. OP
    Fk8Frank
    Fk8Frank New Member
    Jan 13, 2020
    Chicago
    Frank
    Yeah ended up finding out the maf sensor was reading low voltage and high voltage and was basically tripping tf out
    Hollywoo0220 thanked this.
  6. Hollywoo0220
    Feb 10, 2019
    647
    437
    WA
    RJ
    @Fk8Frank
    It’s lucky you paid enough attention to that. Those are the “gremlins” much of the time.
