TunerView Lite Update - New Layouts + Official 2018 Model Info!
KTuner
KTuner
J.R.
Chandler, Arizona
www.KTuner.com
2017 Si
How do you change items on a headunit? Some items are duplicate like there’s two IAT, ECT, or RPM, MPH, on so on. I’d like to change the one that are duplicated on the display.
See the TunerView section of help for the tutorials. www.KTuner.com/KTunerHelp
krees
Mountains of Central PA
2018 Civic Type R & 2020 Ridgeline BE
I believe it's tap and hold on the value but as ktuner suggested, the help system would have all the answers.
varge
George
Greece
Civic 1.5T 4D Elegance EUDM
Hi, I have noticed that it's not possible to connect the tuner view lite with the v1.2 while Android auto is running. If I start the app, connect the v1.2 and then connect my phone over USB (android auto) everything works fine.
Is this expected behaviour?
I run this on a 2017 EUDM head unit
Thanks
David228cx
David
Spain
Thanks
It works fine for me the other way around as well.
What won't work is the auto open with a key configured with honda hack once android auto is on screen.
BR
Myx
Delaware
No option to enable BT in Ktuner. It's still grayed out. I have the latest version of Ktuner. I have 2018 Honda Civic EX CVT. Tunerview is loaded onto my car. I can open it as an app.
I've disconnected the blue tooth cable from my laptop but the car is not seeing it as a bluetooth device because I can't enable it in Ktuner (Grayed out). Will tackle it again tomorrow.
Myx
Delaware
I'm thinking that I may not be able to enable my device for BT Pin code because I have the 1960s version of V1.2 hardware. :p
Looking at the back of the device, I'm not seeing what I'm looking for. Pics attached. I don't think that is the passcode for the unit, like the help link says I should see. Help Link
No biggie! I just ordered an Elm bluetooth device. I should be able to see it with Tunerview when I get it. Currently I have two Elm Wifi Devices. Tunerview doesn't seem to have an option to connect to a Wi-Fi device. I'm good!
Honda Civic 10th gen TunerView Lite Update - New Layouts + Official 2018 Model Info! 20190616_132044
Honda Civic 10th gen TunerView Lite Update - New Layouts + Official 2018 Model Info! 20190616_132058
KTuner
KTuner
J.R.
Chandler, Arizona
www.KTuner.com
2017 Si
Notice you linked to the V1.2 help, which clearly shows a KTunerFlash V1.2 unit, yet you've posted a photo of a V1 unit, which has its own help section and doesn't include bluetooth.
  • Like
Reactions: Myx
Myx
Delaware
Well, there you go. Anyone not in the know, knows now. I may have been the only one not-in-the-know on this one. I'm usually late to the the party most of the time. Gettin' old man!
KTuner
KTuner
J.R.
Chandler, Arizona
www.KTuner.com
2017 Si
We do have an upgrade option if you want to go that route in the future. See the main website.
SilverArrow
Italy
Honda Civic X 1.5 T. Sport
For an actual 18 head unit BT Pin Enable Advanced needs to be used, per the directions. Then follow the rest of what it says. The unit needs to be reset as indicated in all cases when changing the settings.
For a 17 model head unit it's BT Pin Disable and add through bluetooth device settings.
Thanks ktuner! I have connect successfuly my device Obd2-ktuner with tunerview installed on honda connect.
I have a question: can you provide me an alternative device Obd2? I search a device with autooff when my car is off.
KTuner
KTuner
J.R.
Chandler, Arizona
www.KTuner.com
2017 Si
Our units go to sleep after two minutes of inactivity.
