Naruske
Oh wow that seems like it did the trick!!! Thank you so much!You need to set it first from the Connection page, thats where will the app knows which bluetooth you want to connect automatically
Great. If you go to the settings, now you can see the Bluetooth address right under the Bluetooth AutoConnect text.Oh wow that seems like it did the trick!!! Thank you so much!
I found the answer on previous posts .. So excited I'm getting my ktuner deliver tomorrow...Is the tunerview still having issues with pairing bluetooth with the head unit on 2018 Civics??
"Touch and hold" on a gauge you want to change.Can TunerViewLite display IAT2?
If so, how do I do it?
Edward
http://ktuner.com/guides/TunerView_ENG.pdf
mine shows max Gear 5 Gear 6 & Gear 7 does not show on the V2 and also tunerview on the HU.For text readouts of gear there are no limitations on numbers.
i know but it's kinda weird the speedo LCD show 6th & 7th when i switch to manual on my CVT, will try to find out more, maybe a video tomorrow.The V2 also does not limit the value shown. We relay what the ECU is reporting and this has zero to do with our end.
