There is no bluetooth pin on the 17's is there? And this has nothing to do with tune uploading. V2 works fine. My Tunerview app loads but doesn't get readings from the V2.I would suggest going through all the steps again including setting BT PIN and then reloading your tune into the V2. Always the possible that a mistake was made the first time.
I fixed mine. Connecting everytime I have started the car. I made sure my tuner was paired to the Hu. Once paired change the BT Pin to Advance. Open Tunerview and connect through the menu. Make sure you have it set to auto connect. I did unpair my smartphone from the Hu to have only one device connected during the process.Same issue I have and I've seen others here with the same glitch. The Tunerview rep here has responded with surprise but it's clearly a common problem and not good at all. As barebones and basic as my Hondata app was, it connected 100% of the time.
2018 will work yes, I have a 2019 and it works for the 1.2 on the headunit with tunerview...so... I'm scanning through the thread as it's been awhile. Did we get 2018s HUs to work via Bluetooth to a 1.2v? Is it time to 'downgrade' from my 2.0 to a 1.2 yet?
I use tunerview on my 18 si HU all the time! Sometimes it doesn't connect the first time but I would say it is successful 90% of the time. I know I can data log but I haven't really done any so I am not a good one to talk to about my experiences with it. I will say they figured it out, it was fairly simple to install, and it works. I don't remember how to do it though. I would have to relearn it. I use it daily to check on my gauges. I want to figure out how to have the tunerview come up on start up....so... I'm scanning through the thread as it's been awhile. Did we get 2018s HUs to work via Bluetooth to a 1.2v? Is it time to 'downgrade' from my 2.0 to a 1.2 yet?
Follow these steps:...so... I'm scanning through the thread as it's been awhile. Did we get 2018s HUs to work via Bluetooth to a 1.2v? Is it time to 'downgrade' from my 2.0 to a 1.2 yet?
You set that feature up on Honda Hack. Go to the app and there should be an option there or in the settings in the app itself.I want to figure out how to have the tunerview come up on start up.
Lite is for the head unit. Find TunerView on the Google Play Store.hello all
Is it normal that tunerview lite doesn't work on samsung s8?
