The Tuned CivicX Experience & Reliability Thread (for all models)
THATSi
Nick
Orlando FL
17 Civic Si
Vehicle: 2017 Civic Si Sedan
Total tuned time: 24 months
Total tuned mileage: 35k+ miles
Tuning device(s) used: Hondata
Tunes used: Hondata custom tuned by yours truly
Fuel used: BP 93 blend to e30 to e35 from shell
Additional engine mods: PRL flex fuel kit, down pipe and front pipe, MAP 3" race exhaust rest of the way, 27WON W1 turbo, PRL cobra race intake, Injen intercooler and pipes, clutch masters fx400 with SMF
Problems/issues:
None
Driving style: relaxed, hit hard at the track tho
Tuning experience notes: These cars heat soak bad, intercooler upgrade is a must, don't recommend one I got, waiting on #s for 27WOn once released and then debate between it and PRL. If you have an Si and are going to push the redline then Hondata is not the software for it, the VTC runs up to 6900 rpm and then resets to 0 degrees so you can't push past that, hope they get a work around, you can with Ktuner, this is my only real complaint. The W1 is awesome, I've pushed it past where they recommend and have checked shaft end play repeatedly and it's still solid, would like to have seen it be a ball bearing turbo tho. Just little things here and there, but I'm really happy with the car. Nothing quite like dragging a big v8s ass with a 1.5l 4 banger, they get pissed and it puts a big smile on my face
TypeSiR
On a Twisty Road
1.5T Civic, Fit, MX-5, CTR
Yeah, defo on PRL or 27Won FMIC. Have you considered aftermarket grill and hood/hood vents? Or adding oil cooler.
THATSi
Nick
Orlando FL
17 Civic Si
I'll be picking up a turbo blanket and wrap for the down pipe and front pipe to get my IATS down after going to a different intercooler. Oil cooler after that, but as far as parts for power, 27WON when they get the TIP done and a port and polish but reality is the fuel system is maxed. I'm happy with the car as is now, I'd like to focus on suspension and then the seibon carbon fiber body kit, the whole damn car. Moving past the stock fuel system will be expensive and a nightmare at that, unless someone says fuck port injection and gives us a better HPFP and then I'll do the block and head and slap bigger injectors and give it more corn
jacobegg
Jacob
Oklahoma
2016 Honda Civic Touring
Vehicle: 2016 Touring
Total tuned time: 4 Days
Total tuned mileage: About 200 miles
Tuning device(s) used: Hondata Race
Tunes used: Hondata +6 for Injen SRI
Fuel used: 91
Additional engine mods: Injen SRI
Problems/issues: None
Driving style: Normally pretty casual, recently been playing around with the tune!
Tuning experience notes: So far I love having the tune. Bought the Hondata app so I could see my new horsepower readings. Showing about 210HP.. not bad!
Keep an eye on your fuel trims with the Injen intake just to be on the safe side.
THATSi
Nick
Orlando FL
17 Civic Si
No doubt, I had the Injen intake a long time back, so bad I didn't even feel right dumping it on someone looking to buy it, threw it in the trash
jacobegg
Jacob
Oklahoma
What is the safe range? I’ll keep an eye out. also just had the power steering light start flashing while driving. Tried to unplug Hondata so I could plug my dash cam in. Plugged it back in, waited about 30 seconds and it went away?
LTFT and STFT shouldn't exceed + or - 10. As an example I generally see LTFT in the -3 range. Slightly rich but certainly normal. I've seen people with the Injen intake with fuel trims that are all over the place. It's an issue with the MAF. On the other hand, does Hondata have an Injen specific tune?
As far as the ps light, my guess is it had nothing to do with the tune.
THATSi
Nick
Orlando FL
17 Civic Si
You can scale the MAF on Hondata and clean it up but the Injen intake makes it so inconsistent that it's difficult to do. I ran up to -17% when I had mine on and after tuning the hell out of it best I could get out of it -8%. Some people have had different experiences with it, mine personally was terrible
jacobegg
Jacob
Oklahoma
Is this what you mean by all over the place?
First picture is at idle stopped
Second is at idle moving slowly
Honda Civic 10th gen The Tuned CivicX Experience & Reliability Thread (for all models) 94BF9F52-C21C-4F4F-804B-37C36B9A14C8
Honda Civic 10th gen The Tuned CivicX Experience & Reliability Thread (for all models) D8D44BE0-5ABC-45AC-ACAE-2B883BA53C6B
Andre80
white civic
Europe
Civic X 1.5 sport +
[QUOTE = "gtman, post: 711295, membro: 790"] L'ottano è ottimo per mantenere basso il controllo dei colpi, ma a volte le finiture del carburante possono essere "off" con prese aftermarket, bolt on e una melodia base. Che aspetto hanno i tuoi numeri LTFT e STFT? [/ QUOTE]
But he has the international ecu, LTFT varies between -9 / -4 the standard is -6 / -7
Go ahead and save an actual driving datalog for 30 minutes with a couple WOT runs. I'll be happy to read it for you. Post the datalog here as a .zip file.
jacobegg
Jacob
Oklahoma
How do I do that? Still learning all this
Honda Civic 10th gen The Tuned CivicX Experience & Reliability Thread (for all models) IMG_20191111_135149
