TSP Stage 2 Flex Fuel Tune....
gylmar814
gylmar814
Gylmar814
Gylmar
Miami, FL
2017 ABM Civic Si Sedan, 2018 Mazda Cx-5, (RIP) '17 SGP Civic Hatch Ex
To add to my previous comment, I wasn't even in sport mode during my drive. So I didn't even have the most aggressive settings enabled when driving.
Two Step Performance
twostepperformance.com
Well considering the brief drive I did on the tune, I didnt step on the gas hard. Shouldn't I be okay since the tune didnt have to apply the max boost, timing, and fuel adjustments?
If you babied it, the ECU probably saved you. If something was wrong, I'm sure you would know. Glad it didn't go boom.
gylmar814
gylmar814
Gylmar814
Gylmar
Miami, FL
Yep... I reflashed and as normal the knock reset and started at .59 and made it's way down to .49. I did multiple pulls last night and on the Expressway today to test the car and consistently stayed at .49
10civics
bo peep
civicville, IL
civic
if you honked on it with no ethanol and the timing is jacked up on that tune you is mighty lucky.
10civics
bo peep
civicville, IL
civic
Based on this false reading... as I understand it, Ktuner wouldn't dynamically advancing and retarding timing based on an input that isnt indicative of actual ethanol content and the enhanced cooling/antiknock properties ethanol provides. As such, I would not be so confident in k.control's ability to provide protection and preventing knock without actually incurring it. I have read that knock on high ethanol fuel isn't as forgiving as knock on gas... I'll try and find a reference to provide and post it later in an edit. It's been awhile.
The basemaps with 23# if boost were making upwards of ~250 whp, introducing a +5 value across the higher end of the RPM range. @D-RobIMW does quite a bit more... likely with even more timing and boost. Certainly more timing than TSP Stage 1 which, unlike the stock tune or the basemaps, drops the Premium recommendation and calls it a requirement.
You already got a post from the tuner telling you not to do what you're doing. You're his customer and he has your best interests in mind. Just because it worked does not mean it's good for your car and it will continue to work in the future. I'd not be pulled into a false sense of security. Go back to Stage 1/basemaps until you have the proper hardware installed.
with the same ethanol content req as the 23# basemap (E37ish) , how can they get away with more timing (+5)? id say pretty much the same especially with prob more boost to get the numbers with the stock IC.
charleswrivers
Charles
Kingsland, GA
I'd bet the TSP stage 2 is more aggressive than the ethanol enable. I've seen some threads where folks with cobbled together kits before the PnP kits were common that were talking up running substantially higher advances. Ktuner's enable was a conservative starting point.
gylmar814
gylmar814
Gylmar814
Gylmar
Miami, FL
Installed the flex fuel kit, flashed the tsp stage 2 tune and filled up exactly with e38 blend last night... All I can say is wow. Car runs noticeably stronger in the mid-upper rpms and feels like it doesnt want to stop pulling like its hungry. Seeing about 27-28psi peak boost and 2nd gear is pretty much out of question now when stepping on it because tires break loose. On the Expressway it really seems before I could even process anything I'm already in the upwards 90/low 100's. Light throttle tap on 5th is even noticeable as well. One of the first things I noticed is the engine feels and sounds louder at WOT & a buddy of mine who is also on E told me that the power surge you get when running the ethanol blend feels much similar to the feeling of a vtec crossover. I can agree the comparison is actually quite accurate. The engine just really wakes after a certain rpm and doesnt look back. I spent a good 45 min or so just driving around because how fun it was to drive the car again. K. Control is steady at .49. This is all I can remember at the moment. Took it for a late night drive and woke up early today to run some errands on my day off. If I can think of anything else worth mentioning I will report back and do so here for those interested. But so far so good. Loving this flex fuel and the stage 2 map.
Honda Civic 10th gen TSP Stage 2  Flex Fuel Tune.... 20181027_032026
UHx0H
Allan
2017 Civic Hatchback
i've had my ktuner for as long as i've had my hatchback but haven't really looked into based tunes or new features lately since i've been running a custom tune. last night i installed @Two Step Performance flex fuel kit. i uploaded base tune to enable flex fuel and disable ect2 with ktuner and flashed. i'm wondering if these stage 1 and stage 2 flex fuel tunes you guys are talking about are within ktuner or if they are tunes bought from @Two Step Performance ? again i haven't had the chance to look through the new features from ktuner and due to work schedule may not get the chance for a while which is why I'm asking here. any info would be greatly appreciated....thanks!
gylmar814
gylmar814
Gylmar814
Gylmar
Miami, FL
Speaking on this thread alone, we are referring to the tsp stage 1 and stage 2 tune. The stage 2 is a flex fuel tune
UHx0H
Allan
yes, thats what i'm referring to...whether tunes came from tsp or ktuner feature. also is this thread for Si's only or anyone with tsp flex fuel kit?
gylmar814
gylmar814
Gylmar814
Gylmar
Miami, FL
Yup, from tsp. However ktuner had their own flex fuel map. I believe you have to contact them so they can give it to you. Dont quote me on that.
Anyone can join this thread. But the tune is for civic si only. If that's what I were trying to ask.
UHx0H
Allan
thanks!
10GenPearlSi
Old Man
Bob
Houston, Tx
2018 Pearl Si
Just back from a day trip with my TPS Stage 2 E37 tune. Just cruising along and looked at the dash and I was doing 97! It does want to fly! I wasn't even in the sport mode.
Vader_Si
Ryota Watanabe
San Jose
Civic Si Sedan 2018
With the TSP Stage 2 I believe that this is not supported for the Hondata due to the ehtanol content error? This is only supported for the Ktuner?
Siguy
Josh
Civic Si
The tsp stage 2 tune is amazing! The difference from just enabling flex fuel and running the 23.5psi map is unreal! It makes me now question if I really need the 27won turbo upgrade where i would lose out on some of that low end torque! As a daily driver this tune with the factory turbo is all that I currently want, but I'm sure that might change in the future! We are always chasing more!
