I can confidently say that this tune is WELL within the limits of a stock setup running 91 or 93 octane fuel. Any jumps in knock control are likely due to poor fuel quality or questionable driving habits.So what's this knock issue happening, why?
Mine has consistently sat at .49. 93 oct, no other mods, map slot 3. Even on Ktuner starter maps, I was at .49. It may just be your fuel. Drop a gallon of E85 in if you can.Something that i noticed is that the knock ctrl sits at .88 and with the ktuner basemaps i used to sit at .54
I do have 2 gallons of gas left. so it must be the poor fuel.Mine has consistently sat at .49. 93 oct, no other mods, map slot 3. Even on Ktuner starter maps, I was at .49. It may just be your fuel. Drop a gallon of E85 in if you can.
Thanks for responding quickly as usual!!!!I can confidently say that this tune is WELL within the limits of a stock setup running 91 or 93 octane fuel. Any jumps in knock control are likely due to poor fuel quality or questionable driving habits.
Well, fill it up and see what happens. If it’s still not quite there, add a single gallon of E85 (to a mostly full tank) and see where it goes. I lived in IL (STL Metro East) for 5-6 years and the gas is meh all around the state.I do have 2 gallons of gas left. so it must be the poor fuel.
my knock just randomly dropped down to .83 and the car is shaking weird. im going to fill up at shell tomorrow and see what happens.I can confidently say that this tune is WELL within the limits of a stock setup running 91 or 93 octane fuel. Any jumps in knock control are likely due to poor fuel quality or questionable driving habits.
https://www.toptiergas.com/licensedbrands/my knock just randomly dropped down to .83 and the car is shaking weird. im going to fill up at shell tomorrow and see what happens.
so a bunch of message popped up like the error u get when u reflash ur car. so idk whats happening
nopedid you pull the codes if there was any?
Also it's never a good idea to go for top speed runs...
i just flashed to the 19/23 psi map and my car went back to normal and its no longer shakingnope
i just went to the gas station to fill up and retune and everything seems fine now.It went to limp mode or there was a code that caused the problem.
