TSP Stage 1 misfire in cylinder 1/3/4 and running rich
  1. Masked
    Masked Senior Member
    Jul 12, 2019
    57
    Quebec, Canada
    Jos
    2018 Honda Civic Si
    #1 Masked, Aug 9, 2019
    Hi,
    Ran into a problem when I was on the highway today on stage 1 map 3. All the lights started to pop in my dashboard and I was going 70mph. I was really worried about what was going on, I wasnt even on sport mode and it was not letting me change it to sport mode. I took the next exit and looked at the code on KTuner. Turns out it was code p0172 (Running rich). I headed right back at home when I saw this.. I reflashed the car and all the lights went away. I started driving it after to see if the code would come back, and when I gave the car a little bit of gas on map 3 my engine light started to flash and I had 3 codes, all three of them were misfire in 3 different cylinders.. The exhaust was smelling big time like rotten eggs... Have I done any permanent damage to the engine?
    Can someone help me here? I switched back to map 1 after all of this and the lights went away and it was running fine and it didnt smell like rotten eggs anymore... I am running the street tune and always running on 91 octane.
    Thanks!
  2. OP
    Masked
    Jul 12, 2019
    57
    Quebec, Canada
    Jos
    2018 Honda Civic Si
    Also, I was monitoring for a bit the AFR, at idle it was sitting at 12-13 and when on gas it was close to 14, dont know if that could help
  3. D-RobIMW
    D-RobIMW www.imwtuned.com
    Oct 15, 2017
    290
    722
    Carlisle, PA
    Derek
    What intake does the car have?
    What version of the file did you load?
  4. OP
    Masked
    Jul 12, 2019
    57
    Quebec, Canada
    Jos
    2018 Honda Civic Si
    I still have the stock intake and I am running the street tune. I did not upload the race tune. Spark plugs? Air filter? Im not sure here I will need to check this out. Btw, the car only has 15k miles
  5. OP
    Masked
    Jul 12, 2019
    57
    Quebec, Canada
    Jos
    2018 Honda Civic Si
  6. Hollywoo0220
    Hollywoo0220 Customer Service oriented (most of the time) :-)
    Feb 10, 2019
    426
    295
    WA
    RJ
    Tank, Lunar Module, and 1990 Diahatsu Charade
    I think your Octane simply isn’t of high enough quality. Try the 93or better instead of the 91.
  7. OP
    Masked
    Jul 12, 2019
    57
    Quebec, Canada
    Jos
    2018 Honda Civic Si
    Not possible where I live. Highest we have here is 91.. I always run on Shell V-Power..
  8. Hollywoo0220
    Feb 10, 2019
    426
    295
    WA
    RJ
    Sorry to hear that. I just know that knock will be more prevalent with that tune with lower octane fuel. Your mileage is really low so I wouldn’t assume carbon build up. I also understand that Canada’s ethanol content in the fuel is more than not, absent in the processing of it - this, less octane content.
    I’m certain you have already flashed your vehicle back to stock or a different CAN tune at this point. It sucks...I completely get it, but it’s not the tune file.
  9. Jes_si562
    Jes_si562 Senior Member
    Feb 20, 2019
    259
    102
    Long Beach
    Jese
    2018 civic si
    Any luck ?
  10. Design
    Design Senior Member
    Sep 28, 2015
    3,071
    2,634
    Southern California
    09 MS3, 17 ABM Si Sedan
    Word from a couple So Cal tuners is that these cars tend to knock a little more on Shell 91. Not sure why. You can try switching to Chevron and see if you notice an improvement. But I might recommend having their tuner looking over your logs first.
  11. OP
    Masked
    Jul 12, 2019
    57
    Quebec, Canada
    Jos
    2018 Honda Civic Si
    Thats weird.. I flashed the car to the stock tune for the moment, Im gonna wait until I have no gas in the tank left and try with a different brand
  12. hobby-man
    hobby-man Senior Member
    Jun 20, 2018
    668
    461
    Mississauga, ON
    2018 Sport Touring Hatchback 6MT
    Why are we discussing octane and knock? This is clearly a very different issue.
    You're running super rich, enough to throw a code. So you've got a race MAF tune with a stock intake, a boost leak, or something else like leaking injectors.
    If you're sure the tune isn't for a race MAF, then check for a boost leak first.
    Design thanked this.
  13. OP
    Masked
    Jul 12, 2019
    57
    Quebec, Canada
    Jos
    2018 Honda Civic Si
    Thanks for the help, it was weird to me anyway what the octane would change here.. How would be the best way to check for a boost leak? I'm thinking maybe I was on a race MAF tune even though it seemed to be for street MAF. I will check with TSP on that one, because I went back to the stock tune and the car is running perfectly
  14. hobby-man
    Jun 20, 2018
    668
    461
    Mississauga, ON
    That's strange. Was there an "R" anywhere in the tune file name? I feel like I've heard that's on the Race MAF tunes, but don't have a source on that...
    You basically just wanna inspect all hoses, lines, and couplers between the MAF/intake/turbo inlet and the cold pipe of the intercooler, where it is being routed into the intake manifold. Any holes/tears/loose clamps, etc. could cause a boost leak.
  15. Jes_si562
    Feb 20, 2019
    259
    102
    Long Beach
    Jese
    2018 civic si
    If the file has R in it he has the race maf file that's his problem
