TSP Flex Fuel Kit w/Ktuner
LightX
Andrew
2018 Civic Hatchback Sport
Hi there, I’m new here.
Installed TSP Flex fuel for my Civic Sport. My Ktuner is reporting 0% which probably means no power is going to the sensor..? Everything is double checked, double plugged back. Connection is all tight. I plugged the power wire into the slot for the Si and non-Si but no result. Any ideas I should do?.. @Two Step Performance
Thanks.
Thanks.
Did you review the troubleshooting information (if any) along with contact details for support in the instructions provided? A post on a public forum is typically not the best way to reach a company unless you have thoroughly exhausted all other options.
That aside, verifying power at your connections with a multimeter is probably a good start.
KTuner
J.R.
Chandler, Arizona
www.KTuner.com
2017 Si
As mentioned it's best to reach out for support directly through a support outlet.
If you didn't enable the flex fuel feature you may see 0%, but the ethanol voltage value should still be visible in the software as an extra way to verify operation.
LightX
Andrew
I’ve enabled and disabled the necessary stuff. Business hours isn’t back on until Monday and needed quicker response/help since I’m not busy this weekend. How would I check ethanol voltage on the software, I’ve looked around the software and didn’t find any voltage for ethanol.
This is an old screenshot but you’ll find ethanol voltage listed in the sensor list as shown here on the right hand side:
Honda Civic 10th gen TSP Flex Fuel Kit w/Ktuner 11BA7EAD-DD5F-4C8F-B221-116F748DAE9A
LightX
Andrew
I don’t exactly know where to find the voltage still. But I did took a picture. Also, ECT2 reads 32 which is where the signal is supposedly go there.
Is this the Plug n Play kit?
Yes it is the plug n play kit
Honda Civic 10th gen TSP Flex Fuel Kit w/Ktuner 88B23796-B52D-45BB-96D3-1531004BD99A
Honda Civic 10th gen TSP Flex Fuel Kit w/Ktuner 9932B770-7A39-4D6A-9A5B-5E26A875CD9B
Honda Civic 10th gen TSP Flex Fuel Kit w/Ktuner AA7FDD7C-9F32-4A06-BE49-FC2BCDE5197C
dc2turbo
usa
civic,teg
take a picture of the plug you unplugged to plug for the flex fuel
also did you disable ect2 ?
Honda Civic 10th gen TSP Flex Fuel Kit w/Ktuner upload_2018-7-22_2-35-34
LightX
Andrew
I’ve followed the instruction thoroughly over multiple times. Reflashed my ECU a couple of times as well.
Honda Civic 10th gen TSP Flex Fuel Kit w/Ktuner A7849FEA-E4C4-4152-AC37-1328CD774AB9
Honda Civic 10th gen TSP Flex Fuel Kit w/Ktuner 40076384-BA43-4792-A24A-852DB93410A0
Honda Civic 10th gen TSP Flex Fuel Kit w/Ktuner EAC906EA-D296-44DC-AE44-5214FEEFD723
Honda Civic 10th gen TSP Flex Fuel Kit w/Ktuner A1D763B9-5725-4AC4-A240-B7C54E253A2C
Honda Civic 10th gen TSP Flex Fuel Kit w/Ktuner 4DED910E-C04F-47AD-9B68-8A7A5B1013D9
Honda Civic 10th gen TSP Flex Fuel Kit w/Ktuner F15F1542-12E4-4DE8-A1C3-23A3164E9E03
Honda Civic 10th gen TSP Flex Fuel Kit w/Ktuner 8F387AB8-85CC-450C-9F5A-4EE022FA1017
JDM_DOHC_SiR
Uncle Dave
Chula Vista/ Eastlake
2021 Acura TLX Type-S / 2018 Civic Si Coupe
From the looks of that connector .. it seems like the Pin might not be seated correctly?? Kind of hard to tell...:hmm: Also that Fused 12v line looks pretty smashed up as well.. do you have access to a Volt meter to see if you are getting 12V? I believe if you open the cover to the Flex Fuel module there is a BLUE status LED inside that should be on if you are getting voltage:hmm: Some things to check.. but I might be way off...:coffee:
10GenPearlSi
Old Man
Bob
Houston, Tx
2018 Pearl Si
It looks like you pluged the fuse into the empty fuse slot on the inside of the fuse box instead of removing the one on the edge and sharing it like is shown on this video.
EDIT: You will also need to notch the lid to the fusebox to get it back on.
KTuner
J.R.
Chandler, Arizona
www.KTuner.com
2017 Si
Connect the software after you have keyed the vehicle on and it will be in the list you have in your photo, just further down.
Bummslut
Daveed
2018 civic si
Honda Civic 10th gen TSP Flex Fuel Kit w/Ktuner 3922EA87-9D29-4FA5-A07C-4258544D14D9
Honda Civic 10th gen TSP Flex Fuel Kit w/Ktuner 6672C0B8-DCA4-445C-8A0E-F3C11099CCE0
Honda Civic 10th gen TSP Flex Fuel Kit w/Ktuner A1886555-6E88-4B95-8966-E85BC0758E20
Honda Civic 10th gen TSP Flex Fuel Kit w/Ktuner FEA5F097-7DE0-40BB-92F3-D5175CC97EF7
Honda Civic 10th gen TSP Flex Fuel Kit w/Ktuner C6140E81-EBF8-46ED-BF84-7F49C5DDBF2C
Honda Civic 10th gen TSP Flex Fuel Kit w/Ktuner E26C0BA1-1099-45FA-925A-963B8EF11B44
Honda Civic 10th gen TSP Flex Fuel Kit w/Ktuner B0387FC6-1EB2-49BB-BD33-7B332FCA7281
I have the same problem
I installed it Friday but wasn’t able to get it to read the ethanol
JDM_DOHC_SiR
Uncle Dave
Very weird :hmm:…. can you guys that are having the no power issue post a picture of the connector going into the Ethanol sensor showing the wire colors?
maybe the power and ethanol sensor wire are swapped??:dunno:
Bummslut
Daveed
2018 civic si
Honda Civic 10th gen TSP Flex Fuel Kit w/Ktuner 1794CB6D-7095-4D28-98B2-5F202CC06850
I checked that
I seen on another post where they put the wires different
I also checked for power on both plugs
