TSP flex fuel converter issues
Yaku_Si
Andrew
San Diego
2018 civic si coupe
Good Morning !
I installed my Plug and Play flex fuel setup from TSP last night. I followed the instructions down to the bone. I swapped the wires that go into the Ethanol content sensor as well. Looking at the PIDs I see that the Ethanol sensor itself reads 5 volts, but I am still reading a ethanol content of 0%. I took a voltmeter to the harness and started to check for power and ground. I tested these with my vehicle KOEO, the Ktuner FCC read source voltage, the Ethanol content sensor read source voltage as well. All grounds are good as well. There is a 3 pin connector that connects the ECT2 to the dedicated ground and power, it is a white wire, I tested at the 3 pin and found no 5V ref. Now the EC2 sensor lives in hell and I would like to know before I start ripping my bumper off, is that EC2 connector being connected the wrong way or does it only connect one way?
JDM_DOHC_SiR
Uncle Dave
Chula Vista/ Eastlake
2021 Acura TLX Type-S / 2018 Civic Si Coupe
l15b7allturbo
San Diego, CA
2017 Honda Civic Si
Have @francomakou take a look at it.. sounds like a wire might be swapped in the harness....?:hmm: @Two Step Performance
His sensor wire was in the middle, had him switch it out to red, black, white.. black being in the middle like mine.. still didn't work. I'm in Arizona so I can't take a look at it until next week
May need to check his blinker fluid
twostepperformance.com
Good Morning !
Only one way to connect it. It is a bit tricky to get your hands on it but you certainly should not have to remove the bumper. I believe you would actually expect the 5V from the ECU from the wire that is labeled VOUT1 from the Ktuner FFC. The white wire on the 3 pin ECS harness is routed to the input on the FFC, not the ECT2 connector. (which also is a white wire, at the connector)
Yaku_Si
Andrew
San Diego
2018 civic si coupe
I'll check the Vout1 pin for 5V ref. after work. If I find a solution or find the problem I'll let you know ! Thank You !
KTuner
J.R.
Chandler, Arizona
www.KTuner.com
2017 Si
VOUT1 is the ethanol voltage output. VOUT2 is a 2.5v reference for testing. VOUT1 should never be 5v. If the input is 5v ethanol should read 0, as that is out of range and an error signal.
Yaku_Si
Andrew
San Diego
2018 civic si coupe
So I should check VOUT2 for 2.5 volt ref ?
To clarify my statement regarding 5V, I’ve seen 5V from the ECT2 connector (the signal being from the ECU) when not plugged into anything else. 5V would not come from VOUT1 on the FFC. Same wire, wrong end, if that makes any sense.
To avoid any further confusion, I will continue our troubleshooting via direct email, having two channels of communication open at the same time can get messy. Thanks
glossyprimerX
AZ
2017 Sport Hatch MT Sonic Gray
I connected my kit, and was running between 8-10% ethanol, which is to be expected. After driving a bit, I got home and it's now reading approximately 50%. Is anyone having a similar issue? Or can give me some advice to figure it out?
Sorry for the trouble. Check your fuses and also for a loose connection. If you do not see anything obvious, email us at [email protected] for support.
glossyprimerX
AZ
I sent you an email detailing what I was fighting, everything seems to be working great now! Thanks for the response on a SUNDAY! I'm very impressed!
Scarlet
Shawn
Caledonia, WI
2001 Civic LX Sedan - 1998 Civic Hatch - TBD Turbo Something - 2014 Honda Ruckus - 2017 Civic Si Coupe
What was the solution?? I’m now experiencing this after a year and a half..
