Tricky Shifter - new 2018 Civic Manual
  1. Yes - noticable increase in shifter resistance since new
    37.5%
  2. Yes - now that you mention it
    8.9%
  3. No - I can't tell
    14.3%
  4. No - I'm sure it's always been fine. No change since new.
    39.3%
  1. Starion
    Starion Member
    Oct 19, 2018
    39
    Fort Myers, FL
    Matt
    Mitsubishi Starion - modded
    #1 Starion, Nov 5, 2018
    A week into driving my new Sport Hatch Manual, I'm feeling the shifter giving more resistance going in/out of all gears whether in drive or while sitting still. I describe it as "crunchy". Somewhat less smooth to push in gear and pull back to nuetral, even making a bit of a crunchy sound.
    Seems to me that as the clutch breaks in the pedal might need adjusting in case it's no longer fully disengaging at the end of a full pedal press. I mentioned this to the Service Rep and had them take a look at it. Was just told "that's how they normally shift".
    It was definitely smoother initially and I'm being blown off. It still shifts and drives, but I plan to drive this car for the next 10+ years & no good comes of putting extra pressure into a stock shifter repeatedly. I know I'm being picky, but I've rebuilt a few clutch systems and shifters and it's not right.
    Please comment & vote on your experiences. Manual drivers only.
    *PLEASE comment below if your car is different than the 1.5 L manual as the Sport Hatch. I'd like apples to apples data, but also good to know if this extents to other models as well.
  2. parshisa
    parshisa Senior Member
    Jan 11, 2017
    634
    263
    Texas
    Civic X Hatchback LX
    mine drives the same way. and it's not consistent. crunchy, sometimes smooth as butter. I still haven't figured this transmission out with 25K on the clock. on thing I can tell for sure that switching MTF made it much smoother in all gears (including reverse). Although 1-2 is still crunchy. hope this helps
  3. OP
    Starion
    Starion Member
    Oct 19, 2018
    39
    Fort Myers, FL
    Matt
    It does. Thanks for your input.
    I'm not even 1k into this thing and it's not right. I'm not powershifting or slamming gears at all! I typically put short shifters into my cars because I like the feel better, but I'm wanting to confirm this isn't a tranny, clutch, or clutch pedal issue before touching a thing on it. Factory warrantee should mean something, but not appearing to be the case so far.
  4. parshisa
    Jan 11, 2017
    634
    263
    Texas
    Obviously, I cannot guarantee that it is not, but most likely your transmission is just like any other - crunchy and confusing. Like i said, after 25k i am still not 100% sure how to drive it. And i’ve owned manual cars before. You’ll later discover sounda that it makes (while shifting gears) and clunks that clutch makes engaging. There are quite a few treads on here about it. PM me if you want more detiails on my experience with it
  5. Swank
    Swank Senior Member
    Apr 30, 2018
    263
    153
    Calgary
    2018 Civic Si Coupe Black
    My 8th gen Si had it pretty much from the beginning for 3rd gear. Tons of them had it, and many didn't. Fortunately this time my 10th gen Si shifts incredibly well, it's the first car that feels and sounds like a sporty shifter should IMO. With the 8th there was never a permanent fix; from new tranny fluid all the way to a complete tranny rebuild they were all temporary at best and probably more a placebo effect than anything (I never went through any of that, just other's experiences described). Mine never got any worse even after 11 years and once I got used to it I had no additional issues with it (originally I couldn't tell if it was in gear all the way and sometimes it would pop out of gear on it's own as it wasn't fully engaged). The dealership told me on a few occasions the good old "unable to replicate" i.e. unwilling to acknowledge as there is no fix.
    If you try to sell it privately anybody who knows anything about the past 15+ years of civics knows to check for grinding shifters and will either steer clear or lowball you hard. You can try trading it in but you'll never get as much from a dealer as from a private sale.
  6. d1zguy
    d1zguy Senior Member
    Apr 6, 2017
    769
    352
    VA
    19' Mustang GT Premium
    Had the same thing happen on mine. Changed the trans fluid with amsoil and it got smooth immediately and smoother as it broke in.
  7. Robin
    Robin Member
    Oct 27, 2018
    Ontario
    Les
    Civic Hatchback
    The shifts in my Sport are notchy and when cold the first to second crunches a bit, just like the Golf TDi manual I drove previously. It had that issue from new to almost 300,000 kilometres. My habit is to shift out of gear then wait a moment before engaging the next gear. The gearbox in the Sport seems to be getting smoother (at about 7,000 kilometres).
  8. NUshek
    NUshek Senior Member
    Sep 26, 2018
    56
    2018 Civic Sedan EX-T 6MT
    I sometimes have a little crunchiness going into 2nd and 4th but that was present when I got the car and still happens though not all the time.
  9. OP
    Starion
    Starion Member
    Oct 19, 2018
    39
    Fort Myers, FL
    Matt
    #9 Starion, Nov 12, 2018
    Thanks for the replies all. I really appreciate some perspective on this.
    Seems to be another design flaw, although not a hugely massive one, it still affects driveability and enjoyment in the very least. Here in FL, there's no issue with fluids being cold. Perfect temps currently. The cruchy shift is the same upon cold startup as it is after driving it warmed up.
    Odds I'll get Honda to use Amsoil? Unlikely. (I can't do the fluid swap without voiding warranty, unless it's approved per FSM?)
    Equally as unlikely Honda admits there IS an issue at all - and subsequently an issue they must fix under warrantee (but have no fix apparently).
    Also equally as unlikely they even call me back to follow up on this & AC compressor noise. I've called almost daily since last week & no answer (left voicemails) & no return call.
    Between this and the annoying AC whir/whining, I'm not happy.
    Please keep the posts coming!
  10. parshisa
    Jan 11, 2017
    634
    263
    Texas
    F
    Fluid change will not void your warranty. Change it at your convenience and feel the difference.
  11. andromeda
    andromeda Senior Member
    Dec 13, 2016
    284
    77
    Long Island NY
    '04 & '16 Civics
    #11 andromeda, Nov 13, 2018
    Keep in mind what's happening when you shift. The synchronizers must get the substantial counter gear assembly speed turning at a speed consistent with the next gear. That's much easier when upshifting since the counter gear assembly speed is naturally slowing down, but downshifting is much harder because the counter gear assembly speed must be increased. One way to help it is to briefly pause in neutral and take foot off clutch and race the engine so the counter gear assembly speed is a bit faster than what'll be needed for the lower gear, then quickly depress the clutch again and complete the downshift. In days of old, this was easy, when engine speed was directly linked to throttle, but may not be possible today with everything computer linked. A little crunch while the synchronizer does it's thing is probably no big deal. All this is a non-issue with me 'cause I wisely went with the CVT which is the best thing since sliced bread.
  12. d1zguy
    Apr 6, 2017
    769
    352
    VA
    You're onto something but it all fell apart when you said the CVT is the best thing since sliced bread. For my driving style, it was enough to make me trade it in in under 6 months for a manual SI.
    I prefer a whole loaf of bread, not just a slice.
  13. andromeda
    Dec 13, 2016
    284
    77
    Long Island NY
    '04 & '16 Civics
    #13 andromeda, Nov 14, 2018
    More important to me was the somewhat better cruise ratio compared to the available MT and driving ease of the CVT.
    To each his own. Good luck
  14. BirchyBoy
    BirchyBoy Senior Member
    Apr 21, 2017
    130
    57
    GA
    2017 Civic Coupe EX-T 6MT
    I had a new ‘17 EX CVT for a year and 8k miles then traded for a certified ‘17 EX-T manual 8 months ago with 900 miles on it; it has 3,300 on it now. I am in Denver and there are times where the shifting seems notchier than others. I’ll try and pay attention to the temperature when I notice it next time. Denver has lots of temperature swings from 30 to 60 ina day. I want to do a few upgrades to the shifter, mainly the Acuity bits, and may do the fluid as well.
  15. fitz318is
    fitz318is Member
    Feb 6, 2019
    2019 Civic hatch sport
    Our cars must have been built the same day.
