TPMS Issue With Aggressive Setup
  1. Multaq
    Multaq Senior Member
    Dec 16, 2017
    1,228
    437
    New York
    Nick
    2018 Civic LX 6SPD
    Good Evening, I have 18x9.5 rims on my civic with slightly stretched tires 235/40,
    My TPMS light keeps coming on when I do highway driving, I keep turning it off. Has anyone else had this issue?
  2. jgreen16
    jgreen16 Senior Member
    Jan 30, 2016
    477
    311
    Cleveland, OH
    2017 EX-T sedan 6MT, 2020 Civic EX Hatch
    Have you checked the tire pressure in all four tires to make sure they are all reasonably close to each other (+/- 0.5 psi) with a good quality gauge? After verifying the tire pressures are close across all four tires, then do the calibration as outlined below.
    It may take a couple of times to get it to stay cleared. If it doesn't, there could be a malfunction in the system. The TPMS on these cars is an indirect type setup, and does not monitor the actual tire pressures in each tire. It relies instead on sensing the rotational speed of the tires, and if the deviation is more than the allowable tolerance by the system, it will trigger the warning light on the dash.
    Multaq thanked this.
  3. FreshFK7
    FreshFK7 Member
    Oct 15, 2018
    40
    Orange County, CA
    Brent
    2018 Honda Civic Sport Touring Hatchback
    Yes, I am having the same issue. I've taken it to Americas Tire 3 times because they do free air checks. Every time I have had them fill the tires to specs and then re-calibrated and after a short period of time it still comes on. Every time the tires haven't lost much air and the TPMS were working with no issues prior to installing new rims and tires.
  4. lurker_j
    lurker_j Senior Member
    Jun 2, 2018
    471
    295
    '18 WOP FC1
    I started running 40 PSI with my stretched 235/40s and recalibrated. Now I only get the TPMS light if I actually have a drop in pressure (which I did and found that I had a small nail in my tire)
    FreshFK7 thanked this.
  5. OP
    Multaq
    Dec 16, 2017
    1,228
    437
    New York
    Nick
    2018 Civic LX 6SPD
    Update on this,
    After 5 resets my TPMS light no longer comes on.
    vancitysfinest thanked this.
  6. FreshFK7
    FreshFK7 Member
    Oct 15, 2018
    40
    Orange County, CA
    Brent
    I will have to try running 40 PSI...I have the same tire specs as you, so maybe that will help my situation as well? Thanks for the info!
  7. OP
    Multaq
    Dec 16, 2017
    1,228
    437
    New York
    Nick
    2018 Civic LX 6SPD
    I am on 235/40 on 9.5s I still run 35 PSI.
  8. FreshFK7
    FreshFK7 Member
    Oct 15, 2018
    40
    Orange County, CA
    Brent
    I'm on 235/40 on 9.5 with a +40 offset and i'm currently running 35 psi. Ive done 5 calibrations and the damn thing keeps coming on. At this point i'm willing to try anything to keep that damn light from coming on...lol
  9. OP
    Multaq
    Dec 16, 2017
    1,228
    437
    New York
    Nick
    2018 Civic LX 6SPD
    Just keep recalibrating, Thats what I did eventually it stayed off and hasnt come on since, Actually it came on once in the rain, I reset it never came on again
  10. Rc1989
    Rc1989 Senior Member
    May 17, 2019
    79
    2019 civic si
    Re calibrate 3 times in a row to erase tpms.memory. low tire psi light with stay lit for a second or 2 .
  11. Rc1989
    May 17, 2019
    79
    2019 civic si
    Or try this
  12. HellaBagged
    HellaBagged HellaBagged
    Apr 6, 2019
    51
    Antioch, CA
    Jason
    Thank you so much for that post lol, It was so irritating to see my light come on over and over... simply for changing my wheels out for aftermarket.
