2016TouringSLC
- Feb 21, 2016
- 4
- 80
- 53
- Salt Lake City
- 2016 Honda Civic Touring
I've found the Touring "premium" tweeter to sound harsh and unpleasant. Ordered a Hertz Dieci Dt24 that turned out easier to install than I thought. http://amazon.com/Hertz-DT-24-3-Dieci-Dt24/dp/B00DZJ5ICS?ie=UTF8&psc=1&redirect=true&ref_=oh_aui_detailpage_o01_s00
Once you get the door sail off and unplug the speaker connector, the old tweeter pops out by pushing in two plastic latches.
The Hertz flush-mount tweeters fit in nicely to the door sail. Used some hot glue to secure in place. I pushed the tinned speaker wires into the Honda connector (couldn't find an adapter to fit the very-small tweeter connectors). They fit tight enough to make a good connection and I put a dab of hot glue to secure wires to connector. Be sure and trim the tinned connector enough so that no bare wire is showing when pushed in.
Of course you don't need to use the Hertz crossovers since that is handled by the Touring amp that has a separate output for each tweeter.
Wiring Color Code:
Front Right Tweeter: + is light green and - is pink
Front Left Tweeter: + is yellow and - is grey.
Took about 20 min. in total.
This is a nice upgrade that smooths out the harshness and creates a much better sense of presence and air compared to the old tweeters. While the photo makes it look off-center, it really isn't. Easy to get it perfectly centered in door sail.
Wiring Color Code:
