Torque Spec for 17mm Tophat Nut (1 nut also keeps spinning)
j_vang
ATL
18 SI Coupe
Just finished my swift spring install for my 18 SI and have torque specs for all the nuts and bolts but this one. Anyone know the torque spec? Also, I was able to tighten down the driver's side tophat nut but the passenger side just keeps spinning in place. If anyone can shed some light on this I would also greatly appreciate it!
Honda Civic 10th gen Torque Spec for 17mm Tophat Nut (1 nut also keeps spinning) 20200216_140446
zhendexing
Dee
Chicago
2018 civic si coupe
You need insert a hex key through a wrench to properly tighten the nut. Torque spec is 48lb if I remember correctly.
j_vang
j_vang
ATL
18 SI Coupe
You need insert a hex key through a wrench to properly tighten the nut. Torque spec is 48lb if I remember correctly.[/QUOTE
Many thanks. Time to go look for the tool.
zhendexing
Dee
Chicago
2018 civic si coupe
j_vang
j_vang
ATL
18 SI Coupe
Thank you! Thought it looked familiar so I ran out and bought it. So....it's as tight as can be with the open ratchet and allen combo without spin but when I try to torque it down with a torque wrench, like the other side, it still spins. Starting to think I might have to redo this one. Shouldn't spin at all right?
Honda Civic 10th gen Torque Spec for 17mm Tophat Nut (1 nut also keeps spinning) 20200216_192225
blitz
Virginia
2019 Civic Type R
Correct - it should not spin.
For future reference, the tool for this type of process is called a strut nut socket.
Honda Civic 10th gen Torque Spec for 17mm Tophat Nut (1 nut also keeps spinning) lFxShIQ
Honda Civic 10th gen Torque Spec for 17mm Tophat Nut (1 nut also keeps spinning) Z1oAa
Credit: Bimmertips . com
If you have issues with tightening the nut, you can find these strut nut sockets on Amazon. Just get the correct nut size (top hat nut size).
zhendexing
Dee
Chicago
2018 civic si coupe
Use something like a metal pipe to extend the hex key and extend the ratchet with a larger pipe, I used the handle from my floor jack. Don’t do it with car jacked up in the air.
j_vang
j_vang
ATL
18 SI Coupe
Just loosened the nut and impacted it again. Solved the issue. I'm new to impact guns and was playing it safe so I had it on auto-shut off mode to prevent over fastening. Was able to use a torque wrench afterwards with no issues. Overthought this way too much. Thanks for the help everyone.
Oddwayne
Nj
19’ Si coupe & 99 ej6
You shouldn’t use an impact driver to install that nut. Removing is one thing.
JT Si
Place
Car
If he's talking about one of the newer Milwaukee impacts with fastening mode it literally does finger tight. It doesn't hammer the nut on to 40 ftlb or anything like that.
j_vang
j_vang
ATL
18 SI Coupe
Bingo. It's a Milwaukee stubby. Was still able to get a few turns in before finally tightening it.
JT Si
Place
Car
Is it the 3/8 or 1/2? I ordered a 1/2 stubby and I've been waiting for it to arrive (today finally) to use it to install my Swift springs.
I hope it works as well as it's supposed to.
j_vang
j_vang
ATL
18 SI Coupe
3/8. Bought it in preparation for this install and it did not disappoint. Broke every nut and bolt with ease. Using the XC 6.0 and 4.0 battery.
JT Si
Place
Car
Excellent. I just wish I thought about getting it before I did the clutch job. All those subframe bolts would have been so much easier.
j_vang
j_vang
ATL
18 SI Coupe
Dang you did the clutch?! How long did that take you?
