Top Motor mount sounds after installing the Hasport 62A Rear Mount
danny185
Danny
Puerto Rico
Honda Civic SI 2017 Sedan
Hi Guys:
So I installed the Hasport 62A Motor mount a while ago months back (Well not me a shop actually) and now I hear a sound on the top of the car, went to the shop and its the top motor mount. Now the question is, if that motor mount is damage or is it the maybe the hasport 62A mount is to tight etc.
Has anybody had this issue?
REBELXSi
Señor Member
Top motor mount? I've been running the 62A since September (about 8k miles) with no issues.
danny185
Danny
Puerto Rico
Top motor mount? I've been running the 62A since September (about 8k old miles) with no issues.
Yeap the car started sounding very little like a clunking sound when starting the car and shutting it off, also when on 1st gear pulling off, now when I went to the shop they hold the top motor mount to see if it was the mount and the car stopped making the sound!!
So is it a damage top motor mount or there maybe the 62A motor mount was not well mounted don’t know
Barett@27WON
Barett
Vancouver, WA
2017 Civic SI Sedan, 2009 Mazdaspeed 3
Could you better help understand what the Top Motor Mount is? There are three motor mounts: The lower rear mount, the right hand side that attaches to the timing cover, and the left side mount on the transmission.
We have been running the 27WON Rear Motor Mount for thousands of miles without any issues.
danny185
Danny
Puerto Rico
Ok, if you open the hood is the one on the left.
vzdragon
Luis
Massachusetts
www.luisvalle.net
2017 Honda Civic Si
I think I'm having this same issue as well. I can hear a faint cluncking sound. Did you just replace the left motor mount next to the transmission? Or was your rearrmount not installed correctly
danny185
Danny
Puerto Rico
I changed only the rear motor mount! I think that my top mount is just bad! We checked and the rear motor mount is well mounted
Radsolutionz
Rahim
DFW area Texas
2018 Honda Civic SI 4dr
Would there be any positive effect to replacing all mounts? Is it necessary? I'm using a 62a and am very happy with results so far
bbeem
Ben
Iowa
what rear motor mount are you guys preferring? trying to find a middle ground, just don't want to be rattled to death. thanks.
joshhjackson2112
Josh
Raleigh, North Carolina
18' SI
The 27won I have used to rattle me quite a bit. *Trigger warning* I believe I have broke it in good after about 1,000 miles or more. When it is cold outside, the vibrations are more noticeable. I was worried the vibrations would be too much at first and was going to uninstall but decided to give it a chance. I will never take it off now. Vibrations have honest to God have gotten better.
Justin
Justin
New Jersey
2017 Civic SI
Perhaps it’s your intake rattling? I hear that same clunking and it only began happening after I replaced my intake with the PRLA CAI
fkturboindo
Osmar
indonesia
Civic FK4 1.5 Turbo Hatchback
Hello, I just installed hasport 62a rear motor mount, this morning. I think increase vibration and noise. how long is break in/ broken in period? Confuse about back to stock or stay use Hasport 62A. sorry for my bad english. Thank you for your help / opinion.
Honda Civic 10th gen Top Motor mount sounds after installing the Hasport 62A Rear Mount IMG-20200703-WA0042
Honda Civic 10th gen Top Motor mount sounds after installing the Hasport 62A Rear Mount IMG-20200703-WA0045
Honda Civic 10th gen Top Motor mount sounds after installing the Hasport 62A Rear Mount IMG-20200703-WA0040
LuisXVI
Luis Alberto
Lima, PERĂš
2016 HONDA CIVIC EX-T (FC1) / 1996 NISSAN BLUEBIRD SSS (U13/SR18de)
Hi there‼
I need some help please, I've the CVT version, and the hydraulic mount (right side I believe) produce an annoying noise, then I found the HASPORT Full Mount Kit, but it says is for 6MT only.
I've some doubts, if I couldn't install this complete kit in my CVT CIVIC, may I use the OEM left mount in combination with the HASPORT Full kit âť“ And if the answer is YES, how about the performance after combine a 62a mount with a OEM left mountâť“
The final option and undesirable will be keep the engine mount system on stock, going against the forum rules ?
fkturboindo
Osmar
indonesia
Hi there‼
Sorry brotha, I don't know about full mount, I was installed only rear engine mount, the vibration was kill me and so annoying for daily use (my car is 2017 civic hatchback, CVT, same like yours). Then, I installed Hardrace engine mount, and rear toe kit. comfort and stick to the ground enough for daily driven.
my opinion: hasport is a good product for track/ race car, not for daily use or traffic jam car. lol.
Hope your car is fine and have no problem, keep the modification fun. Gbu
Honda Civic 10th gen Top Motor mount sounds after installing the Hasport 62A Rear Mount 20200715_100949
Honda Civic 10th gen Top Motor mount sounds after installing the Hasport 62A Rear Mount 20200715_100942
du ma may
anthony
htown
racezzz
shoot mine is smooth after 5k miles, reason why i like 27won because is a full solid on the back to frame and only use one bushing.
