Honda-Swiss
- Fabian
- Aug 12, 2017
- 6
- 110
- 65
- Switzerland
- Honda Civic Type-R FK8
shouldn't rub is the what I've gathered, but I've just sold my Titan 7 to another local CTR owner and he'll be lowing on Swift, so will report back on the rubbing. but not that i've heard of thus far.I am currently lowered on Eibach springs, does anyone know if a 19x9.5 +45 with 265/35/19 will rub?
Sold your set for what particular reason?shouldn't rub is the what I've gathered, but I've just sold my Titan 7 to another local CTR owner and he'll be lowing on Swift, so will report back on the rubbing. but not that i've heard of thus far.
Yea, decided I wanted some more lip, so ordered these...Sold your set for what particular reason?
Just curious, with your setup what will be the performance/ride differences compared to the stock wheels?Wheels:
Titan 7 T-S5
Satin Titanium
18x9.5 ET45
18.1 lbs
Tires:
Michelin Pilot Sport 4S
265/35/18
Lugs:
Rays L42 Dura-nuts
Gunmetal
Suspension:
Stock
Wheels:
Titan 7 T-S5
Satin Titanium
18x9.5 ET45
18.1 lbs
Tires:
265/35/18
Lugs:
Rays L42 Dura-nuts
Gunmetal
Suspension:
Stock
I'm curious as well! Do you plan on lowering it and if you do, will it rub? I'm lowered on swift and I plan on going this same setup, the only thing that's holding me back at the moment is making sure this setup doesn't rub while on swifts.Just curious, with your setup what will be the performance/ride differences compared to the stock wheels?
Ride quality, handling, turn in basically the driving dynamics of the car?
I use my car as a daily driver. No plans for tracking. The stock wheels/tires feel a little sharper in handling due to the very low profile tires. But, the stock wheels feel heavier. The new setup is definitely smoother and less rattling/jarring. With the higher profile tires, it’s definitely less stressful when driving on bad roads. For everyday driving and cruising, the new setup is definitely recommended. 265 tires protect the rims better, but no guarantee if you hit a curb at a higher rate of speed. The Michelin’s provide a smoother and more quiet ride, last longer, and cost less. The overall driving dynamics haven’t changed much. The car drives/handles pretty similar to stock setup. This setup was actually recommended by Evasive Motorsports.Just curious, with your setup what will be the performance/ride differences compared to the stock wheels?
I’m still debating on whether to lower it or not. I’m waiting for the Eibach camber kit with sensor mount to be released. I personally like the way it looks without lowering. As far as I know, the 45 offset shouldn’t rub with the eibach kit (less than 1 inch drop). I’ve heard of rubbing issues with the 35 offset (unless you go with a less wide tire). If you get the 19 inch size, it rubs without lowering and on full load or hard cornering. Titan 7’s website lists all motorsport shops that carry their wheels. Those shops might be able to tell you what setups work or not and whether rubbing is an issue or not.I'm curious as well! Do you plan on lowering it and if you do, will it rub? I'm lowered on swift and I plan on going this same setup, the only thing that's holding me back at the moment is making sure this setup doesn't rub while on swifts.
elmoTK said: ↑I am currently lowered on Eibach springs, does anyone know if a 19x9.5 +45 with 265/35/19 will rub?
