Tire suggestions for 2019 Type R?
  1. et4891
    et4891 Member
    Apr 3, 2019
    Vancouver
    ET
    Civic Type R 2019
    Sorry I am new with car stuffs, please bare with me if questions are quite dumb.
    Recently I got a Type R, and I realized it comes with a summer tire but in Vancouver the weather here is mostly rainy all year and some snow during the winter. I am not using the car for tracks. So I am thinking of getting a set of new tires which would fit for the whole year without changing between winter / summer tires when season comes.
    I did google around but don't really know what should be good. I thought of changing rim to 19" but quite a few people and read this post https://www.roadandtrack.com/car-cu...5683452/smaller-lighter-wheels-hurt-handling/ that keeping the original rim would be the best for the car.
    So wondering if there's any good suggestion with good price for tires?
    Thanks in advance for any suggestions and help.
  2. Vic_L
    Vic_L Senior Member
    Jan 21, 2019
    50
    British Columbia, Canada
    Victor
    Correct, going down to 18" or 19" will affect the handling; as mentioned in the Road & Track article, Honda used the specific size and offset to help eliminate/minimize torque steer.
    The problem with 20" wheel size, however, is the limited selection of tires.
    Your selection will *basically* be only UHP summers.
    From what I can quickly dig up...for all-season at stock size are:
    - Federal Formoza FD2
    - Nitto Neo Gen
    And...some Indonesian / Chinese brand tires..
    Brand-name winter tires on stock 245/30/R20 size are available, though.
    et4891 thanked this.
  3. tinyman392
    tinyman392 Senior Member
    May 21, 2018
    377
    196
    Illinois
    Marcus
    '18 Civic Type R (RR)
    If you have the cash to burn, Honda does make a 19x8.5 + 60 rim (for previous gen CTR) when paired with 245/35/19 has the same exact dimensions as the current CTR. Motegi also makes a 19x8.5 +53 rim as well. You'll be able to get a better, and possibly cheaper tire selection from that. Otherwise, with stock wheels, the NeoGen is really the only UHP all-season around. It's only an OK all-season tire though, I'm running it right now.
  4. OP
    et4891
    et4891 Member
    Apr 3, 2019
    Vancouver
    ET
    Civic Type R 2019
    I am trying to google around for what you mentioned 19x8.5 + 60 rim (for previous gen CTR) but I don't see much though. Is there a site which you know I can take a look?
    I will check out the Motegi canadian website :D thanks thanks
    Also, one last question as for Nitto Neo Gen, is it this one https://www.nittotire.com/passenger-tires/neo-gen-all-season-ultra-high-performance-tire/ and why do you think it's only an OK all-season tire though?
  5. Vic_L
    Vic_L Senior Member
    Jan 21, 2019
    50
    Victor
    #5 Vic_L, Apr 11, 2019
    9th (FK2) generation Civic Type-R (e.g. one that was only available for Japan + EU market only).
    Just a quick Google search...but...these ones:
    https://www.tegiwaimports.com/selec...9-alloy-wheel-black-civic-type-r-fk2-fk8.html
    • 19" diameter
    • 5 x 120 bolt pattern
    • +60 offset
    • 8.5" wide
    The Nitto tires are more...UHP Summer...than All-season...
    Compare that to the tread pattern of something like the Michelin Pilot Sport A/S 3+
  6. jetydosa
    jetydosa Senior Member
    May 29, 2017
    68
    37
    ATL
    2017 CTR
    I would go 18s, 245/40-18 and a good all season tire. Tons and tons of 18" wheel and tire options! And the best protection from potholes etc vs a 19.
    Even a +40 or possibly even higher (lower #) offset you won't have any appreciable torque steer, especially if you are not tracking.
  7. tinyman392
    May 21, 2018
    377
    196
    Illinois
    Marcus
    @Vic_L already linked to the wheel. The Motegi wheel is on TireRack, it seems to be the only place I can find it (I've linked to the black set, but silver is also an option). As for the Nitto NeoGen, it isn't the best at displacing anything really. It's OK in the rain, OK in the snow, but it's tread pattern makes it a little slippery in both conditions. In the rain you'll spin pretty easily (compared to other tires) while in the snow, you will have to take it easy. Basically, if it's not dry, they do have more trouble hooking up, which is unfortunate because they actually can handle the cold decently well.
  8. Vic_L
    Vic_L Senior Member
    Jan 21, 2019
    50
    Victor
  9. tinyman392
    May 21, 2018
    377
    196
    Illinois
    Marcus
    I was looking at those for 19" wheels (245/35/19 which matches the 245/30/20 diameter). Unfortunately, if you do use the Motive 245/35/20, it will cause a slight difference in speedo (~1.5%), I don't believe it'll cause any issues in terms of fit if you're using the stock suspension though, but don't quote me on the latter.
  10. Mrgracer
    Mrgracer Member
    Feb 1, 2019
    TN
    Justin
    2019 Civic Type R
  11. Vic_L
    Vic_L Senior Member
    Jan 21, 2019
    50
    Victor
    Oh! I totally did not double check to see that they do not carry 245/30/20, but only down to 245/35/20.
  12. OP
    et4891
    et4891 Member
    Apr 3, 2019
    Vancouver
    ET
    Civic Type R 2019
    ah, I checked the link for 9th (FK2) generation Civic Type-R. It is really quite expensive for my budget :(
    Really thanks for the info, but if with the 19", I believe going for the Michelin Pilot Sport A/S 3+ would be a better match than Nitto right? (If I am looking for all season to drive somewhere always rainy and some snow in the winter)
  13. TypeSiR
    TypeSiR Senior Member
    May 15, 2017
    257
    130
    Occupation:
    Car Driver
    2016 Civic EXT, 2017 CRV, 2016 MX5 6MT, 2016 Mazda6 GT, 2013 Odyssey
    #13 TypeSiR, Apr 16, 2019 at 9:43 PM
    Quite a few CTR owners run 255/35/20 and more selections with this size. Check it out. That’s what I’ll be running before shelling out more $ for a set of 19” Motegi wheels.
  14. Zeffy94
    Zeffy94 Senior Member
    Mar 26, 2017
    543
    430
    Doylestown, PA
    2018 Honda Civic Type R
    I ran 245/35/20 Conti DWS 06 without issue when the weather was cold/snowy. Now I’m on Michelin Pilot Sport 4s and my god these tires are worth every penny.
    I definitely don’t think running all seasons all year round is the way to go though. This car feels like a car costing three times it’s value with good summer tires on. With the DWS 06 I could still take corners much faster than everyone else but there is a lot of wheel spin in the low gears when you push it.
    You don’t need to track it to get your moneys worth with summer tires. Really for track use you should have a pair of Pilot Sport Cup 2s or similar.
    Plus, I believe the Michelin’s will last longer than the stock Contis, so when it gets cold out again I can store them until the next spring. Until then I’m gonna enjoy pushing this car.
    Kevindust and et4891 thanked this.
  15. FifStreet
    FifStreet Senior Member
    Aug 8, 2018
    112
    Oswego NY
    Michael
    '18 PMM Civic Type R '07 MR Fit Sport (RIP)
    For all season tires I went with 255/35R20 on the stock wheels. no issues with fitment and there is a much larger selection of tire options at that size.
