Hi guys, similar issue yesterday - 20 yards before my garage and after a ~30 minute journey, the "pressures low" warning came on. I measured the pressure (warm tires) and it was ~40 on all 4 tires. Measured again cold this morning and it's exactly 36 psi, i.e. 1 psi more than required - I guessed they did it for precaution to be just a little over, which is sth I do too. I'll use the TPMS recalibration to try and reset the warning, as there's obviously nothing wrong with the tire pressure. Any other ides - please share. Thanks everyone.Oh yessss – sounds about right, thanks. I'll def check into that
I stand corrected, just saw the above and of course my placard says 33 for the rear as well, so I guess they set them all at 36, i.e. 3 over for the rear and 1 for the front.Hi guys, similar issue yesterday - 20 yards before my garage and after a ~30 minute journey, the "pressures low" warning came on. I measured the pressure (warm tires) and it was ~40 on all 4 tires. Measured again cold this morning and it's exactly 36 psi, i.e. 1 psi more than required - I guessed they did it for precaution to be just a little over, which is sth I do too. I'll use the TPMS recalibration to try and reset the warning, as there's obviously nothing wrong with the tire pressure. Any other ides - please share. Thanks everyone.
40 psi was after driving for half an hour; then when I measured them cold in the morning (10 minutes ago) they were all exactly 36 psi. So the TPMS is acting up, therefore I'm saying I'll recalibrate.TPMS should not go of when it's at 40 psi. I would recalibrate.
I know, read what you wrote. Im just saying maybe your TPMS was set at 20, which would cause it to go off at 40.40 psi was after driving for half an hour; then when I measured them cold in the morning (10 minutes ago) they were all exactly 36 psi. So the TPMS is acting up, therefore I'm saying I'll recalibrate.
I'm OCD, I have to check that at least twice a week. CoveredHas anyone else had the wrong tire pressure set from the dealer? Should be 35/33 front/rear, mine can 40-42 on all 4 tires. Had it a week now, and just checked it and noticed.
Good Man!I spray my car down with detailer and wipe it down every day before I got sleep. Even if I didn't drive anywhere...
That's right...baby it very much.I spray my car down with detailer and wipe it down every day before I got sleep. Even if I didn't drive anywhere...
After lowering mine after 30 miles and towards the night mine Tire pressure warning went off, did recalibration and is fine now. Also pulls straight.Same thing just happened to me, today. Got a low pressure warning light. I did a recalibration, came on, again, within 20 miles. I got home and checked the tire pressures, and every tire, was a 50.5psi. Clearly didn’t air them down, during the PDI. I’ve driven 480 miles, with them at the 50.5psi. I’ll air them down, recalibrate, and see how it goes.
