None of the wheels have sensors. The Civic uses the ABS system to monitor the rotation of the wheels. When one of them is not inflated properly it rotates at a different speed and will trigger the warning.All tires are at 32lbs.
Does compact spare have a sensor? I didn't check it.
The TPMS stuff should be a sticky thread.None of the wheels have sensors. The Civic uses the ABS system to monitor the rotation of the wheels. When one of them is not inflated properly it rotates at a different speed and will trigger the warning.
I just came back from my dealer and the service guy did 3 calibrations one after the other and no more low tire pressure alert.Having the exact same issue. Taking to the dealer this weekend. I re-calibrated 3 times to no avail.
Thats good to hear. I actually took it in on Saturday (didn't schedule an appointment as I usually just walk in and they attend to the issue) and they told me they can't see me till Monday even though my issue is literally so small. So i'm calling in today and seeing if they can address it. I'm running the factory tires as of now so I don't see why the light would come on at all since all of my pressures are literally perfect. If its a sensor, i'm assuming thats covered by warranty but we'll see.I just came back from my dealer and the service guy did 3 calibrations one after the other and no more low tire pressure alert.
He said my going to 225's could have thrown off the calibration as its very sensitive to tire rotations. A larger tire can cause a problem if so little like a 215 to a 225.
Omg how have I not heard of this sorcery?None of the wheels have sensors. The Civic uses the ABS system to monitor the rotation of the wheels. When one of them is not inflated properly it rotates at a different speed and will trigger the warning.
Well, filling the tires to spec and re-calibrating is probably a good first step for them. While I am sure you have tried the same thing, they are required to at least see if the normal steps work.Update: had a terrible experience at the Service department today. I called ahead before I left about my issue and I asked if I can just walk in and the lady said yes. So I drive 40 mins in horrible traffic to the dealer only to find out when I walk in that they're COMPLETELY booked and the lady that told me I could walk in was wrong. So in short, he pretty much came around with an air hose to fill each of the tires up to 34 psi and sent me on my way and told me to schedule an appt if it comes back. I havent driven enough for it to calibrate but Im 95% sure it will come back. Trip was a complete waste.
True. I guess im more upset about the lady telling me its perfectly okay to walk in when in reality I needed an appointment. She works for the service department so it's kind of sad when someone who works there doesnt even know their own schedule. If I had come later and made an appointment, at least they could keep the car and diagnose the issue if the normal steps didnt work rather than someone shoving air into my tires (when I did that just the day before) and sending me on my way.Well, filling the tires to spec and re-calibrating is probably a good first step for them. While I am sure you have tried the same thing, they are required to at least see if the normal steps work.
