Design
- Sep 28, 2015
- 28
- 3,329
- 2,903
- Southern California
- 09 MS3, 17 ABM Si Sedan
- #76
The assembly line seems to be much different than a typical rebuild. The former leaves almost no wear particles (in theory) whereby molybdenum paste is used during different phases of Honda's assembly process (so I'm told). That in turn mixes with the factory fill. Good discussion here:It is an anti-wear additive. Which I don't understand for new engine break in? When I assemble engines, I put moly lube on the camshaft to assure adequate lube during the first seconds after first start. Which is critical.
But this seems to me to be the opposite of what you want for piston ring / cylinder wall break-in. You WANT those to wear while the cylinder wall is still rough enough after honing to seat those rings. Piston ring sealing is the most important part of break-in in my mind. If you get a really good ring seat. It helps everything! If the rings seal, then you not only get better power and mileage because the compression is better, but the engine lasts much longer because combustion products are not leaking past them, which burns the oil film off the cylinder walls. Then lets acidic / corrosive compounds created by combustion into the oil. Which then attacks everything inside the engine.
https://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=91344
jay said:There are two ways an engine breaks-in. One is where the asperities collide and instantaneously weld and tear away. That, obviously, leaves more (but smaller) asperities and it generates a wear particle that can cause more wear.
The other way is by plastic deformation where the asperities are mushed down rather than torn away. Plastic deformation leaves no jagged edges and generates no wear particle. Moly is a highly polar AW/AF additive that greatly aids break in by plastic deformation.
