The Lowered Thread
  1. CombsCivicHatch
    CombsCivicHatch Senior Member
    Mar 21, 2017
    112
    125
    Gallatin, TN
    Civic Hatchback Sport
    I figured I would start this to help have a reference for people asking questions about how different springs/coilovers sit.
    So if you would
    State the following
    Model: Sedan/Coupe/Hatback
    Suspension: ex. Eibach pro kit/Sportline, BC Coilover, Bags
    Any modifications needed?: ex. Trim bump stops, camber kit
    And a picture showing how the car sits.
    bembol and slothy thanked this.
  2. Mannyp93
    Mannyp93 Senior Member
    Dec 24, 2015
    564
    332
    Central Jersey
    2010 Civic EX, 2016 Civic EX
    2016 EX
    Ksport coilovers
    Only mods done were to stiffen the shocks to allow for passenger weight without risking bottoming out.
    Considering a rear camber kit. -3.8 in the Left Rear and -2.8 in the Right Rear. Alignment setup is off a 2015 Si since the shop did not have the numbers for this setup yet.
    CombsCivicHatch thanked this.
  3. Beenawhile
    Beenawhile Senior Member
    Mar 31, 2017
    109
    72
    Occupation:
    Film Producer / Director
    Falls Church, Virginia
    2017 Honda Civic Hatchback Sport Touring
    #3 Beenawhile, Apr 16, 2017
    Lowered the car today. Eibach Sportlines. SPC rear camber arms. Fkx Racing 20mm bolt-on spacers. And I finally threw on the smoked side markers :)
    My installer was super impressed with how flush the drop looked with stock rims, spacers and springs. It all works perfectly. Thanks to Jonnys_honda for planting the idea. I've got a little bit of rub on my front passenger well (near the marker), but nothing too bad. We'll see how they behave once I've got everything aligned and the springs have had a few days to settle.
    And yes - My car is literally COVERED in pollen.
    IMG_1584.jpg IMG_1585.jpg IMG_1587.jpg IMG_1588.jpg IMG_1589.jpg IMG_1590.jpg IMG_1591.jpg
    He trimmed the bumper stops per Eibach's included instructions - 17mm in the front, 20mm in the back. I saw 22mm mentioned somewhere on this forum but decided to go with Eibach's recommendation. 2017 HB ST.
  4. slothy
    slothy Senior Member
    Mar 31, 2017
    361
    171
    Bay Area, CA
    2017 Civic Hatchback Sport Touring
    @Beenawhile, did you get the spacers solely for aesthetics? Or do they help in some way with the lowered stance? Also, link?
  5. Beenawhile
    Mar 31, 2017
    109
    72
    Occupation:
    The spacers are solely for aesthetics. If anything - and this is based on nothing more than what I've read - they're probably not good for the car in the long run. BUT, I think they should be fine on a DD. Link below - I think I paid $130 for four shipped.
    http://www.fkxracing.com/FKX-RACING-HUB-CENTRIC-SPACERS-20MM-06-15-HONDA-CIVIC-818003.htm
    All this being said, Slothy, if you're thinking about dropping your car on coils or dropping it any lower than me then I wouldn't recommend anything more than 15mm without rolling your fenders. I'm getting the smallest bit of rubbing so any lower and it would be much worse.
    CivicWhtEXL thanked this.
  6. ediblebirch
    ediblebirch Senior Member
    Jan 8, 2016
    145
    61
    Oregon
    2017 FK7 ST
    Is there any long term affects on using spacers? Wheel bearings, etc?
  7. omigulay
    omigulay Senior Member
    Oct 18, 2016
    228
    117
    Vancouver, Canada
    2017 Civic Sport hatchback
    How's the ride on eibach lowering springs compared to coilovers and stock? I'm contemplating on eibach springs, however don't really want my stock shocks to blow after some time...
  8. BLK Hatch
    BLK Hatch Senior Member
    May 6, 2017
    102
    40
    2017 Civic Hatchback Sport, 1960 Classic Mini w/B16B
    I dont see how your shock can blow out unless your bumpstop failed completely or you did not install them back on. If you want to avoid a shock/strut failure from an engineering stand point. removed your strut or shock and check the total travel, then find out the max compression on the bump stop. The bump stop is there so you dont bottom out, although having a bump stop too tall on a lower spring will limit the spring compression travel.
    Hope that helps.
  9. katied
    katied Member
    Oct 27, 2016
    39
    58
    OH
    2017 CBP Honda Civic Sedan EX-T 6MT
    Anyone with an air suspension system on their 10th gen?
    TxSi thanked this.
  10. TxSi
    TxSi H Badge Faithful
    Apr 24, 2017
    87
    61
    Occupation:
    Exterior Lighting Specialist
    Houston Tx
    2017 Honda Civic Ex HB FK7
    Id like to know this as well!
    katied thanked this.
  11. OP
    CombsCivicHatch
    Mar 21, 2017
    112
    125
    Gallatin, TN
    Got my sport lines and control arms put on a dew weeks ago a long with an alignment.
    civic-phill, JDM_DOHC_SiR and katied thanked this.
  12. civic-phill
    civic-phill Member
    May 26, 2017
    Toronto, Ontario, Canada
    2017 Civic Sport Hatchback
    @CombsCivicHatch - Your ride looks great!! :cool: I can't wait to get a set on my 2017 Sport Hatch!
    Any rubbing during aggressive turning or rubbing at all?
    What else do you notice?
    Thanks!
  13. TxSi
    Apr 24, 2017
    87
    61
    Occupation:
    Houston Tx
    There can be yes. Most likely is wheel bearings. But it really depends in a variety of things. Different cars are different with spacers. Your driving style can affect everything too. Just really depends. May get a issue in a year or never! Hard to say. But they can induce extra stress on wheel bearings for sure! I rode on some on my ek hatch for a year with no probs, but my friend rode on some in his ek hatch for 2mths and had bad wheel bearings occur so...at your own discretion!
  14. OP
    CombsCivicHatch
    Mar 21, 2017
    112
    125
    Gallatin, TN
    Thanks. A few weeks ago I had family from out of town over and I drove them all around for a week so I was pretty much full load with everyone in it. I just have to be careful to miss pretty large pot holes. Other than that it handles great and I haven't had any rubbing issues. I drove up to Cincy today and was able to have someone take a decent rolling shot of it.
    Triple_peaz and JDM_DOHC_SiR thanked this.
  15. Jproots
    Jproots Member
    Apr 25, 2017
    Soledad, Ca
    2011 BMW 335i Msport, 2016 F150, 2017 Honda Civic Ext-t
    This was before my black grille :(
    Triple_peaz, Dying2Live, xenon04 and 3 others thanked this.
