Swift Springs Civic Si
BoostedDreams
Heisenburg
South East Florida
2019 Type R, 2006 Mazda 6
Got my alignment done today. Front is fine. The rear camber is significant, it’s going to need a camber kit. What do you guys think?
Honda Civic 10th gen Swift Springs Civic Si 67375C5A-8095-4C06-9604-88B374856D4A
powerwing
Jacy
SOCAL
Civic Sport Hatch
Did the alignment shop enter your car information into the alignment machine? The reason why I ask is because the range of the rear camber to be within spec seems like a huge spread. -.6 to -2.1...
From my experience, shortened tire life from camber wear happens with toe being off. As long as toe is good, running negative camber shouldn't be that much of an issue in terms of tire life. All of it will depend on how you drive of course.
Having a camber kit is ALWAYS better. I'm still running the springs without one.
BoostedDreams
Heisenburg
South East Florida
I don’t know if they did. Do you know what the factory front/rear camber is? He said ideally I should be just under -1.0.
Hondanickx
Nick
Belgium
I contacted Swift springs again and asked them if the springs also could be used on a base sedan or if they needed aftermarket shocks.They replied that they also tested the springs on the base models and that they will work without any problems .So these springs work on all the models ,si ,sport and base models.
Are all these alignment spec's in degrees ? Or degrees ,minutes ,seconds? Seems weird that most cars already have such different caster settings left and right in stock form. Mostly from factory they are dead even for example 5.8 degrees left and right. (The older honda's had them that way).
powerwing
Jacy
SOCAL
Civic Sport Hatch
Most cars will not have the same alignment specs between driver and passenger side, even ride height is different from the factory between driver and passenger side. I have never seen caster being exactly the same, a lot of standard alignment shops wont even touch caster. You have to take an extra step to measure caster, and since it actually has the least amount of effect in terms of tire wear, to the tire shops/alignment shops its not worth the hassle to mess with them.
Hondanickx
Nick
Belgium
Ride height only affects camber and/or toe settings .Caster doesn't change if you're lowered or stock .It only changes if you had the front subframe loose .My 98 civic always had the same caster settings left and right from factory .Only when i changed the subframe the settings were off. Caster settings are always measured its part of the alignment ,and it only requires turning the wheels left and right to measure it.So i don't see the extra step they have to do to measure it...
Caster affects straight true driving and turn in greatly .So to me it's just as important as toe and camber .
powerwing
Jacy
SOCAL
Civic Sport Hatch
I don't know where you learned that ride height doesn't affect caster, but it definitely does.
Just picture the pivot point of the top of the shock and the pivot point of the control arm distance getting closer (when you lower it.. it gets closer to each other), that means if you already have a positive angle then it will become more extreme. The only time you can say caster wouldn't change is if it is, for some reason, set at zero.
Hondanickx
Nick
Belgium
You are talking about Camber ,not Caster...
bahndrvr
Trevor
Melbourne, Fl
2017 Civic Si White Orchid Pearl, 1983 Foxbody 4 eye Notchback
Shows the 2016-2018 Civic in the printout from the alignment machine he posted...
Maplestory
Kt
theworld
2019 civic si sedan crystal black pearl
When the spring settles in does it get a Little lower?
JT Si
Place
Car
Immediately after install, my rears dropped lower than my fronts. After a few months, the front settled in to match.
A little later this morning I'll go measure my current ride height and list the settled in drop amounts I got.
JT Si
Place
Car
===OEM ------ SWIFT
FR: 14-1/8" ---- 13-1/4"
FL: 14-3/16" --- 13-3/8"
RR: 14-1/2" ---- 13-1/2"
RL: 14-5/16" --- 13-5/16"
Total drop
FR: 7/8"
FL: 13/16"
RR: 1"
RL: 1"
So, after a long settling period of several months and lots of hard driving, it dropped the front 7/8" and the rear 1".
Initially, it looked like the fronts only dropped 1/2 inch or so.
pinhead66
Bay Area, CA
2019 Civic Si Sedan, 2018 Odyssey EX-L
===OEM ------ SWIFT
Total drop
FR: 7/8"
FL: 13/16"
RR: 1"
RL: 1"
Thanks for the detailed info. Any issues with concrete parking lot curbs/bumpers or speed bumps? I wouldn't think so considering the drop is pretty mild.
JT Si
Place
Car
I scrape rarely. And I scrape much, much less now than my 2014 Malibu 2LTZ does with its factory suspension.
I've even got the muffler from the Yonaka exhaust that hangs down quite a bit and I've never hit anything with it so far.
