Sway bar / rear engine mount
  1. I Am Noobmaster69
    Jul 1, 2019
    42
    Houston
    Andrew
    2019 Civic Sport
    Hey guys
    I got a 2019 Civic Sport Sedan not to long ago, and am looking for little things I can do to improve performance.
    I’ve seen people talking about the sway bar and engine brace, and was wondering if any one could get me some more info and links for specific products?
    Thanks Everybody!
  2. 360glitch
    360glitch Moderator
    3,876
    3,732
    2017 Civic Si Sedan
    You probably do not want a rear motor mount for your application but a rear sway bar can help handing out a bit.
    I Am Noobmaster69 thanked this.
  3. civilian
    civilian Senior Member
    Jun 1, 2019
    173
    134
    James
    2019 Honda Civic Touring
    Note that the Sport has a sway bar that, while better than the LX, is less impactful than the one found on the EX and Touring.
    LX
    : 25.0 mm x 4.0 mm (tubular) / 16.5 mm (solid)
    Sport: 26.5 mm x 4.5 mm (tubular) / 16.5 mm (solid)
    EX: 26.5 mm x 4.5 mm (tubular) / 17.0 mm (solid)
    Touring: 26.5 mm x 4.5 mm (tubular) / 17.0 mm (solid)
  4. OP
    I Am Noobmaster69
    Jul 1, 2019
    42
    Houston
    Andrew
    2019 Civic Sport
    What exactly would the motor mount do to the performance? I’ve seen people talking about them but I’m still trying to learn about what they do
  5. OP
    I Am Noobmaster69
    Jul 1, 2019
    42
    Houston
    Andrew
    2019 Civic Sport
    So how much would an upgraded sway bar help? And are there any you would recommend?
  6. civilian
    Jun 1, 2019
    173
    134
    James
    I am not qualified to answer that question but what I can tell you is that I am extremely satisfied with the sway bar in my Touring Sedan.
  7. OP
    I Am Noobmaster69
    Jul 1, 2019
    42
    Houston
    Andrew
    2019 Civic Sport
    Also would adding a strut bar help anything substantially?
  8. civilian
    Jun 1, 2019
    173
    134
    James
    How hard are you going to drive your Civic? Describe your driving style, how fast you drive, what kind of roads you ride, city vs. country, etc.
  9. OP
    I Am Noobmaster69
    Jul 1, 2019
    42
    Houston
    Andrew
    2019 Civic Sport
    Mainly a daily driver, but I live in houston so there’s ample opportunity on our roads to open it up and have a little fun but nothing too crazy. Like I wouldn’t take it on a track but race down the highway at 100+ if it’s empty
  10. racer
    racer Senior Member
    Jul 31, 2018
    641
    385
    Virginia
    Dave
    2018 Civic Si sedan.
    The motor mount mod you hear of is often for drives with tuned engines (more hp) that helps with getting traction by reducing motor movement when starting off accelerating. Likely not something you need to concern yourself with.
    Sway Bars (Anti Roll bars) help reduce the car lean when cornering. Depending on how large a bar (particularly a rear bar) that is installed, will quicken the vehicles rotation around a corner. Most often the Autocross guys talk about changing out their sway bars to improve handling (rotation). The safest/cheapest option is often to buy a used bar from someone who is upgrading. So, someone with an EX or Si who is going to larger bars often sells the old bars for cheap. Si bars are thicker and would bolt right on.
