SCOPESYS
- Geoff
- Aug 27, 2018
- 68
- 2,505
- 1,550
- MD
- 2018 Honda Civic SI Coupe. . . . . . . .1987 Nissan Maxima Wagon. . . . . . . . . . .1987 Nissan Pulsar NX . . . . . . . . . . . . . . . . . .1987 Nissan Maxima Wagon (2nd Donor Wagon for parts)
Yesterday, I was swapping out a Brake Bulb for a new modern LED bulb, and hit an issue.
I had purchased on of those Flashing Led Bulbs, with the idea or replacing the Center Upper Brake light on the Si , with one that does the strobe/flash/on function, but should have check first, as the Upper Center Brake Light on the Si, ends up being a multi Led Bar. (Duhhhh)
Not a total loss, I decided to put it on my 1987 Maxima Wagon instead.
Note: A 1987 car, without a lot of intelligent electronics. (You would think !!)
Apart from the fact that the Bulb stye was wrong style (Maxima needed a bayonet type bulb) I modified the LED to be a Bayonet , fitted it, and it was Great ..Worked really well. The Center Bake has 2 Bulbs, and I just replaced one, but the combined effect was most acceptable.
Then I noticed that a warning light came on on the dash, every time I applied the Brakes. Never seen that before in 30 years.
Turns out, even on my 30 year old car, the car had enough "intelligence" to detect if even just ONE of the two center bulbs, or either of the two main side bake light bulb were "Blown", and would then display a warning on the Dash.
(The LED bulb draws so much less current than the old Incandescent bulbs, that it was, to all intent and purposes, not there)
Well, what does this have to do with CIVICx cars ?
Only as a warning to be careful what you replace. I would imagine that the modern CivicX has far more sophisticated electronics and fault detection systems, so when replacing bulbs etc, what sort of concerns are there that these fault detection systems (f they exist), will not be upset which such changes ??
Just a though ....
BTW: I still want my Si's Center Upper Brake Light to strobe & Flash, so I intend to SPLICE IN an Inline Strobe Module ... and SCREW the useless warranty !!
I can just imagine :
Dealer :-
"Your warranty on your A/C Compressor is voided, because you did a MOD, and fitted a Flasher to your brake light"
Just a though ....
Dealer :-
